strange wireless problem (433MHz)
3 posts / 0 new
I`ve a strange problem with my wireless communication. I`m using the AT90CAN32 to communicate wireless with my PC. The purpose of the pcb i`ve developed, is to drive two motors with PWM. Each time there is communication the 2 PWM registers will be updated.
The problem is that sometimes the motor disturbs... I think that updating the OCR registers with a high frequency is a problem? You will find my code below:
SIGNAL
SIGNAL(SIG_UART1_RECV)
//DATA FORMAT:  | <00> |  | <00> |  | <80> | 8 x  |  |
	ontvangen = UDR1;
	if(data_detected == 1)
		if( read_count < (DATABYTES + 1) )
			data[read_count] = ontvangen;
			if(read_count < 8)
				crc_byte = crc_byte + data[read_count];
			read_count++;
			//CRC check
			while (crc_byte > 255)
				crc_byte = crc_byte - 255;
			if( (crc_byte == data[8]) && (ontvangen == 80) )
				//Juiste data
				data_received = 8;
				reset_vars();
				reset_vars();
				crc_byte = 0;
		if(ontvangen == 80 && vorige_waarde == 255)
			data_detected = 1;
			read_count = 0;
		vorige_waarde = ontvangen;
MOTOR FUNCTION
void motor_control(void)
	pwm_value1 = (data[0] * 256) + data[1];
	pwm_value2 = (data[2] * 256) + data[3];
	//bepalen of het 'gas' los is of niet
	if(pwm_value2 == 255)
		PORTE = (1<<PE2);
		PORTE &= ~(1 << PE2);
	if(pwm_value1 == 255)
		PORTB = (1<<PB7);
		PORTB &= ~(1 << PB7);
	OCR1A = pwm_value1;
	OCR1B = pwm_value1;
	OCR3A = pwm_value2;
	OCR3B = pwm_value2;
MAIN
	do{
		if(data_received == 8)
			no_signal_counter = 0;
			motor_control();
			if(data[4] == 20)
				PORTA = (1<<PA4);
				PORTA &= ~(1 << PA4);
			data_received = 2;
	}while(1);
edit: when i send a pwm value for one time, it seems that the motor run smoothly. It goes wrong when updating the OCR registers frequently.
Shouldn't you need to wait for the serial data to receive completely before doing this
ontvangen = UDR1;
What PWM mode do you set? for driving motor usually i use Phase Correct PWM mode. So when the OCR register receives new value the remaining pulse are keep unchanged until the timer register reaches top. The result is PWM pulse still kept synchronized .
KISS - Keep It Simple Stupid!
the serial data is completely received when entering the SIGNAL ?
/* USART1, Rx Complete */
#define USART1_RX_vect			_VECTOR(32)
#define SIG_UART1_RECV			_VECTOR(32)
the init:
void uart_init(void)
	UBRR1H = 0x00;	/* 19200 bps */
	UBRR1L = 0x33;
	/* 8-databit, no parity & 2 stop bits */
	UCSR1C = (1<<USBS1) | (0<<UCSZ12) | (1<<UCSZ11) | (1<<UCSZ10);
	/* Enable receiver and transmitter and interrupt */
	UCSR1B = (1<<RXCIE1) | (1<<RXEN1) | (1<<TXEN1);
void timer0_init(void)
	//prescaler = 64 = 1.024ms
	TCCR0A = (0<<CS02) | (1<<CS01) | (1<<CS00);
	TIMSK0 = (1<<TOIE0);
void timer1_init(void)
	TCCR1A = (1<<COM1A1) | (1<<COM1B1) | (1<<COM1B0) | (1<<WGM11) | (0<<WGM10);
	TCCR1B = (0<<WGM13) | (1<<WGM12) | (0<<CS12) | (0<<CS11) | (1<<CS10);
	/* prescaler = 1 => 31.25 KHz */
	OCR1A = 255;	/* max = 512 (9-bits) */
	OCR1B = 255;	/* max = 512 (9-bits) */
void timer3_init(void)
	TCCR3A = (1<<COM3A1) | (1<<COM3B1) | (1<<COM3B0) | (1<<WGM31) | (0<<WGM30);
	TCCR3B = (0<<WGM33) | (1<<WGM32) | (0<<CS32) | (0<<CS31) | (1<<CS30);
	OCR3A = 255;	/* max = 512 (9-bits) */
	OCR3B = 255;	/* max = 512 (9-bits) */
void port_init(void)
	DDRB |= (1<<PB5) | (1<<PB6) | (1<<PB7);		/* PWM output 31.25 KHz + inverted */
	DDRE |= (1<<PE3) | (1<<PE4) | (1<<PE2);		/* PWM output 31.25 KHz + inverted */
	DDRA |= (1<<PA3) | (1<<PA4);
	DDRD |= (1<<PD0) | (1<<PD1);
