PLEASE BIG HELP ATTiny13 ADC
10 posts / 0 new
I'm newbie to this ADC concept anyway i think i pretty much get it running from values 0 and 5vc (discrete input) but that's not my idea.
I need to turn on an output when i reach more than 2.5V please help me with this.
I just need a guide how to calculate the value i got from the ADC, i'm lost completely.
Here is the code:
#include
#include
int ReadADC(char);
int val=0;
int main (void)
	DDRB |= (1 << 1);
	DDRB &= ~(1 << 4);
	ADMUX |= (1 << REFS0);
	ADMUX |= (1 << MUX0) | (0 << MUX0);
	ADCSRA |= 0b10000000;
	while (1)
		val = ReadADC(2); <<-- Here how i calculate [val] i need to compare it when is bigger than 2.5v
	return 1;
int ReadADC(char n)
      ADMUX = n;			//n is a channer between 0 and 7
      ADMUX |= 0b01000000;	//0x40 = 0b01000000 = AVcc = voltage reference
      ADCSRA |= 0b01000100;	//0x44;= 0b01000100	bit6= start ADC conversion, bit2= div factor = ck/16
      while((ADCSRA & 0x40) !=0){}; //wait for conv complete
      return ADC;
Please help me i really needs this to get going on a project. I know you guys have this expertise.
This selects the internal voltage reference which only goes up to 1.1v. You will need to use vcc as a reference.
Once you have done that, then you just need to test if the returned value is greater than 1024 * vcc / 2.5.
Steve A.
Thanks a lot for a quick response, but i'm a newbie on this. VCC needs to be setup some how??
I change my code due to your suggestion like this.
// ATtiny13
// ADC Module
#include
#define F_CPU 8000000UL
#include
int ReadADC();
int val=0;
int main (void)
	DDRB |= (1 << 1);
	DDRB &= ~(1 << 4);
	PORTB &= ~(1 << 4);
	ADMUX |= (0 << REFS0); // VCC as Reference
	ADMUX |= (1 << MUX1) | (0 << MUX0); // ADC2 PB.4
	ADCSRA |= (1 << ADEN); // Enable ADC
	while (1)
		val = ReadADC();
		if (val > 2048)
			PORTB &= ~(1 << 1);
			PORTB |= (1 << 1);
	return 1;
int ReadADC()
      ADCSRA |= (1 << ADSC); // Start Converstion
      return ADC;
I really appreciate the big help.
should be
ADMUX &= ~(1 << REFS0);
This seems not right
 while (1)
      val = ReadADC();
      if (val > 2048)
         PORTB &= ~(1 << 1);
         PORTB |= (1 << 1);
I think that should be like this
while (1)
	val = ReadADC();
	if( val > 511)	// <-- mind this
		PORTB &= ~(1 << 1);
		PORTB |= (1 << 1);
or simply the code can be like this
while (1)
	if(ReadADC() > 511)
		PORTB &= ~(1 << 1);
		PORTB |= (1 << 1);
Please keep in mind that ADC value never exceeds 1023 since the ADC's resolution is 10bit (0..1023)
Roughly,
0 means 0 volt, 1023 means 5 volt and if you need 2.5 volt then 1023/2 = 511.
Big enough? :D
KISS - Keep It Simple Stupid!
Yep thanks a lot man. my ADC is working fine. I think i want to revisit the concept because there's a lot stuff that is a little fuzzy for me.
Any good reference you can tell me to make my ADC expertise stronger?
      if (val > 2048)
Sorry, that was my fault. I meant to say 1024 * 2.5/ vcc. That would make 512 (or 511) the correct answer.
Steve A.
Thanks any way, it is working fine now.
I will post the code for someone who need it in the future.
// ATtiny13
// ADC Module
#include
#include
int ReadADC();
int val=0;
int main (void)
	DDRB |= (1 << 1);
	DDRB &= ~(1 << 4);
	PORTB &= ~(1 << 4);
	while (1)
		val = ReadADC();
		if (val > 625)
			PORTB &= ~(1 << 1);
			PORTB |= (1 << 1);
	return 1;
int ReadADC()
	  ADMUX = 2;// ADC2 PB.4
      return ADC;
#define F_CPU 80000000UL
Quite an old post it is.
As much as i know, attiny 13 runs at 9.6 mhz. Since the CKDIV8 fuse is set by default. It should run at 1.2 mhz. But he F_CPU as 8 mhz. Wont the delays work erratically ? I mean we are telling the compiler that the tiny 13 is running at 8 mhz but it isnt.
Quite an old post indeed, so why resurrect it with a remark on something that has nothing at all to do with the problem?
What delays? There aren't any.
As much as I know, the #define you're remarking on does not affect the code at all.
Locked because there is no material benefit to anyone in exhuming this thread.
Topic locked
