low cost / low part / slow speed contactless communication
19 posts / 0 new
I'm looking for a REALLY simple contactless method of providing a serial data stream between a sealed 'AVR' and external controller. I'm thinking in the 300-1200 baud type speeds. Needs to be < US$15 for the receiver components.
Options I've seen so far, FM receiver SIP unit - quite bulky, Nordic 2.4Ghz probably more complex than I need.
Any other leads / suggestions or an induction based solution?
Carl
how low is low speed? You can use an inductive loop. Or even an LED. They are both about the cheapest solutions I can come up with.
hi,
work on 300 bps for the moment. Any examples of inductive loop scematics / designs that you can point me at?
Carl
LED - probably not feasable on this occasion
zkvii wrote:
Carl
must it be RF-based?
A $3 IR receiver + a cheap IR diode and LOTS of code will do it.
Maybe look at the stuff for RFID - they use inductive loops at around 150khz.
Does the sealed unit have a good power supply? I think an inductively coupled system could be put together, but I'd guess that the current draw would be more than that of the $5 433 MHz RF Tx and Rx units.
Additionally, how big of a surface area do you have for your coil? 6" diameter coil reasonable, or looking for small size?
Also, what is the gap between the two coils, mm/cm/meters?
Can your physical design allow them to be parallel to each other, sharing the same central axis?
Unidirectional or bi-directional communications?
Significant RF or magnetic interference in the environment?
Just some thoughts...
Try Dick Cappels site.
http://www.cappels.org/dproj/minmassrf/Min_Mass_Wireless_Coupler.html
There are other examples also.
Rick
What is the shielding/sealing material that encloses the AVR? What are the RF properties? Will the signal be able to get out? What if a bright eyed, bushy tailed young marketing exec suddenly decided that a metallic housing would look cool? I say go with IR if you can.
If you think education is expensive, try ignorance.
I have on my list of things to try (right next to the toybox of cool chip samples) to try to use Hall effect sensors & electromagnets to try to communicate through plastic (or similar) housings. Haven't gotten there yet. ;)
I suggest you to use a pair of zigBee modules, for example from maxstream. You can use it in a simple transparent mode like a serial line.
try Linx devices.
www.linx.com
IrDA may be worth considering.
zkvii wrote:
Carl
rfm12 - spi tranceicer
http://www.mikrocontroller.net/t...
/bingo
carrier pigeons
Smoke signals?
Sorry, couldn't resist...
Guillem.
Please. Let's be futuristic. Telepathy.
carrier pigeons
Smoke signals?
Now, exactly HOW are you going to get those to/from a sealed AVR?
[Well, I suppose you COULD release the magic smoke--but only once.]
Lee
Solenoid activated by the AVR timer system to open a pigeon cage. The only problem with this system is the high timing jitter and multipathing.
Hi guys,
Thanks for the pointers - the rfm, lynx and Dick Cappels method are all possibles - lots more research needed.
With regard to other options:
telepathy, only seems to work when it is other peoples interface problems
smoke signals - we have fire bans on here, so I don't think that will be allowed
pigeons - I've already got the TX bit sorted, it is really the RX bit and feeding requirements would reduce the running effeciencies somewhat
Cheers,
Carl
