IAR-Cannot place data in EEPROM
14 posts / 0 new
Hi there,
I don't know if this is the right forum for posting an IAR C compiler question, but I cannot see any other forum for posting.
My problem is that I cannot place data in an EEPROM absolute segment. My code is:
/* Data placement in EEPROM */
#define EEPROM_FAULTS 0x00
__eeprom const UC noFault @ EEPROM_FAULTS = 0x00;
while I can place data in FLASH using:
/* Data placement in FLASH*/
#define FLASH_FAULTS 0x1FF
__flash const UC noFault @ FLASH_FAULTS = 0x00;
I have read the IAR C Compiler manual and I think that I am doing it well.
When I inport the debug file in AVRStudio in order to debug it I cannot see the data in EEPROM, while I can see it in FLASH.
Why this happened???
Michael.
Michael.
User of:
IAR Embedded Workbench C/C++ Compiler
Altium Designer
May need to use the upload/download file function from debug.
First of all I am sorry for posting the same question a couple of times. It was a mistake.
John,
I tried this, but nothing is happened. The debug file that IAR generates is named program.d90 (ubrof 8). For uploading an EEPROM file I need a program.eep. How can I generate an .eep file with only the eeprom initialized addresses???
Michael.
Michael.
User of:
Altium Designer
That I'm stuck with as I haven't used the EEPROM with C of any description, just with ASM.
Someone will jump in with help for sure. :)
ps I have found this in the docs folder of IAR "Avr EEPROM howto.htm" May help.
Use the linker extra options to generate 2 files for FLASH AND EEPROM.
-Ointel-extended,(CODE)=flash.a90
-Ointel-extended,(XDATA)=eeprom.a90
Jens,
Can you give me some details of doing this, because it's seems a little bit difficult to get it.
Thanks a lot.
Michael.
Michael.
User of:
Altium Designer
To get correct output of EEPROM hex file:
- in linker options set output format to debug(ubrof)
- in linker extra options check 'use command line options' and type into the edit field:
-Ointel-standard,(CODE)=.code.hex
-Ointel-standard,(XDATA)=.eeprom.hex
This will produce a xxx.code.hex to program into flash and a xxx.eeprom.hex to program into the EEPROM.
Hope this helps,
Jörg.
icarus1I don't know if this is the right forum for posting an IAR C compiler question, but I cannot see any other forum for posting.[/quote wrote:
Michael, this is the correct forum for all AVR programming platforms except for avr-gcc.
Guys,
Thank you all.
Michael.
Michael.
User of:
Altium Designer
Jörg,
I have followed your suggestions:
Then I wrote those lines in my code:
__eeprom const unsigned char version[] @ 0xF0 = "v.1.00";
__eeprom const UC h @ EEPROM_HOURS = 0x00;
__eeprom const UC d15 @ EEPROM_DAYS_15 = 0x00;
__eeprom const UC d180 @ EEPROM_DAYS_180 = 0x00;
__eeprom const UC f @ EEPROM_FAULTS = 0x00;
and after compilation the final result inside the xxx.eeprom.hex is this:
:00000101FF
:00000001FF
which is not seem to be what I expect.
Please,
Where am I wrong???
Michael.
Michael.
User of:
Altium Designer
I mostly use it in the following way:
#define _INPUTCONF      2000
#pragma location = _INPUTCONF
__root __eeprom U32 CInputConf = 0x00000000L;
Please look up the meaning of the _root keyword in your Compiler doc (I am a bit busy :-))
Jörg.
Jörg,
Very thanks for your very kind help. I wrote the word __root in front of my instructions and everything solved.
Maybe I have to read more about the compiler options.
Michael.
Michael.
User of:
Altium Designer
try...
#include
__eeprom int i;
int tmp;
void main(void)
  i = 0xA7;     // write 0xA7 to EEPROM
  tmp = i;      // read from EEPROM into tmp
hope it'll help,
pak
