buildroot 2.2.0 rc2 issue
4 posts / 0 new
Hi all,
I have downloaded the buildroot, ran make atngw100_defconfig and then make and get the following error when it hits libdaemon:
checking whether make sets $(MAKE)... (cached) yes
checking build system type... x86_64-pc-linux-gnu
checking host system type... Invalid configuration `avr32-linux': machine `avr32' not recognized
configure: error: /bin/sh ./config.sub avr32-linux failed
Is this a typo in a setup script somewhere perhaps?
You must update autoconf tools on your machine, specially the config.sub and config.guess scripts in /usr/share/automake/config.{sub,guess} are not updated.
Old Linux distribution? The proper config.sub and config.guess with AVR32 support has been available for 2 years now, and I think most distributions updated their autoconf/make/whatever packages pretty often.
Hans-Christian
Thanks hce!
It doesn't seem to be an old distro: 2.6.9-55.0.6.ELsmp #1 SMP Tue Sep 4 21:05:30 EDT 2007 x86_64 x86_64 x86_64 GNU/Linux
Looking at the automake versions available in /usr/share, there are 1.4 to 1.9.. perhaps my setup is using an older version
Thanks again!
Update, I've moved to rc3 and gave up on the linux servers. The autoconf, automake etc were all too old and the admin is quite a grouch about upgrading anything. So I've been running a ubuntu 8.04 virtual machine using vmware player, and the default build works fine.
However, when I try to add the python packages on, I get the following:
/usr/bin/gcc -pthread  -Xlinker -export-dynamic -o python \
			Modules/python.o \
			libpython2.4.a -lpthread -ldl  -lutil   -lm
libpython2.4.a(posixmodule.o): In function `posix_tmpnam':
posixmodule.c:(.text+0x7f4): warning: the use of `tmpnam_r' is dangerous, better use `mkstemp'
libpython2.4.a(posixmodule.o): In function `posix_tempnam':
posixmodule.c:(.text+0x8c4): warning: the use of `tempnam' is dangerous, better use `mkstemp'
make[1]: `Parser/pgen' is up to date.
make[1]: Leaving directory `/home/jstewart/work/buildroot-avr32-v2.2.0-rc3/build_avr32/Python-2.4.2'
/bin/bash: line 8: -/usr/bin/make: No such file or directory
make: *** [/home/jstewart/work/buildroot-avr32-v2.2.0-rc3/build_avr32/Python-2.4.2/.hostpython] Error 127
/usr/bin/make is definitely there, is there perhaps a typo with that "-" in front of the path that is causing a problem? No idea what file might have that, though.
Any ideas? Also will Python 2.5 be included in the final release of the buildroot?
Thanks!
