Max LCD resolution with NGW100
5 posts / 0 new
What is the maximum LCD resolution with the NGW100?
What are the hardware and software factors that affect the acheivable LCD resolution on the NGW100? I plan to use Linux.
Thanks for reading the post,
-drt
2048 x 2048, but it depends on how many colours you plan to show at the same time...
I would not recommend going larger than WQVGA with the AP7000, 16-bit SDRAM and Linux. VGA might work if you up the priority for the LCDC.
Hans-Christian
I would like to have 1024x768 resolutiuon with 16bpp. Is it possible with Linux running? Or If I have a RTOS and a custom GUI on it?
That is about 94 MB/s IMHO, I would have made a design with 32-bit SDRAM for that. You will need a small system which only does the graphics to get that to work, Linux would not be usable for that.
Hans-Christian
Thanks for the information.
I will follow your suggestion.
