PWM in C
4 posts / 0 new
/edit
This thread evolved from a questions to answers post...
Where I am at...
The counting sequence is determined by the setting of the WGM01 and WGM00 bits located in the Timer/Counter Control Register (TCCR0A) and the WGM02 bit located in the Timer/Counter Control Register B (TCCR0B).
#include
int main (void)
//ATMega88
//SET OUTPUT
DDRD |= (1 << 6);
//Set TCCR0A - Set OC0A on Compare Match Up-Count,
//Clear OC0A on Compare Match Down-Count, Phase
//Correct PWM Mode
TCCR0A |= (1 << COM0A1) | (1 << COM0A0) |(1 << WGM00);
//Set Clock Source
TCCR0B |= (1 << CS00); //no prescaling
while (1)
Per datasheet:
"The PRTIM0 bit in “Minimizing Power Consumption” on page 42 must be written to zero to
enable Timer/Counter0 module."
added enable line, saw a quick flash from PD6 and then nothing...
#include
int main (void)
//ATMega88
//SET OUTPUT
DDRD |= (1 << 6);
//Correct PWM Mode
//Set Clock Source
//Enable Timer/Counter 0
PRR |= (0 << PRTIM0);
while (1)
Well I kind of got it. I set the Output Compare Register A to a value between 0 - 255 and it changes the intensity of the LED. Thing is that I thought my settings for TCCR0A automatically set the TOP and BOTTOM to 0xFF and 0x00. Nothing like talking to yourself :? . Hmm...
#include
int main (void)
//ATMega88
//Set Output PD6
DDRD |= (1 << 6);
//Set TCCR0A
//Set Clock Source
//Set Output Compare Register A
OCR0A = 255;
   //Run Forever
   while (1)
