Problem compiling kernel modules
7 posts / 0 new
I'm using the Atmel buildroot 2.1.0, and I'm looking to get modules up and running (so I can develop a custom driver).
I have changed busybox and linux to support modules (and insmod, etc), but I can't seem to get the module itself to compile correctly.
Using the following command ...
make ARCH=avr32 CROSS_COMPILE=avr32-linux- -C /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23 M=`pwd`
... I get my test.ko file. But when I try to use insmod, I get the following error ...
test: version magic '2.6.23 mod_unload AVR32v1' should be '2.6.23 AVR32v1'
insmod: cannot insert 'test.ko': Invalid module format (-1): Exec format error
If I try the following (manual) compile ...
avr32-linux-gcc -O2 -DMODULE -D__KERNEL__ nanotest.c -c -o nanotest.o -I /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include
... I get the following errors ...
In file included from /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/linux/notifier.h:14,
                 from /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/linux/memory_hotplug.h:7,
                 from /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/linux/mmzone.h:493,
                 from /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/linux/gfp.h:4,
                 from /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/linux/slab.h:14,
                 from /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/linux/percpu.h:5,
                 from /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/asm-generic/local.h:4,
                 from /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/asm/local.h:4,
                 from /usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/linux/module.h:18,
                 from nanotest.c:3:
/usr/local/dev/avr32/buildroot/project_build_avr32_nofpu/atngw100-base/linux-2.6.23/include/linux/rwsem.h:24:65: error: asm/rwsem.h: No such file or directory
Can anyone shed some light on what's wrong, and how I might fix it ?
Mark
As a quick update, I have noticed that there is no /lib/modules directory on my target !!
I guess this could be the cause ?
Where are the files I need to copy ?
make modules_install INSTALL_MOD_PATH=/media/usbdisk-1/
(INSTALL_MOD_PATH have to be set to the path where you have mounted the SD card or where you want the modules..)
Life's to short for waiting on slow CPU's
I've solved this problem simply by installing the module directly into the kernel (rather than using insmod, etc).
Since my device driver was very simple, it only took a few turns to get this going.
Hello. I'm having the same problem with the message
"error: asm/rwsem.h: no such file or directory". Can anybody provide a makefile which would successfully build the kernel module.
Well what commands are you executing to get the error?
That's because you've enabled module versioning, and the kernel you built the module for has module unloading support enabled while the kernel installed on your target does not. That makes your module incompatible with the running kernel.
Replacing the kernel image on the target with the one built by buildroot should fix it.
That's because you've left out a lot of flags that are supposed to be present when compiling kernel modules -- in this case I think it's "-include /.../autoconf.h" that's the main omission. In general, building modules manually is very difficult -- use the kernel's build system instead.
Please see Documentation/kbuild/modules.txt for more information.
