I can see how you stimulate a regular i/o port with the stimulus file.
Is it possible to get UART input ? Or would I have to produce the actual start bit... stop bit on the RXD pin with the correct cycle timing?
Foreground code that waits in a loop can be changed by manually altering the loop condition. Can you force a RX interrupt manually ?
