problem in running a code
7 posts / 0 new
any help! i'm using avr gcc and avr studio 4!
when i run the this code, it gives the error:
undefined reference to `adc_init'
the code
#include "main.h"
#include "adc.h"
int main()
	initialize();
void initialize(void)
	adc_init();//initialize adc
        sei();//enable global interrupts
and i have defined these:
main.h
#include
#include
#include
void initialize(void);
adc.h
//function declaration
void adc_init(void);
and adc.c
#include "main.h"
#include "adc.h"
void adc_init(void)
	//select reference voltage
    //AVCC with external capacitor at AREF pin
	ADMUX |= (1<<REFS0);
    //enable ADC with dummy conversion
	ADCSRA |= (1<<ADEN)|(1<<ADIE);
You need to declare adc_init as external in adc.h, e.g.
extern void adc_init(void);
Compiles ok for me. (You don't need extern on a function prototype).
I would guess adc.c is not being compiled for some reason. If I remove adc.c from the project, I can duplicate your error message.
Looks like the linker is not including adc.o. Check your makefile....
C: i = "told you so";
what have you done?
Code:
it can't compile successfully even when i have declared with extern.
how do i check my makefile
maybe you forgot to add the adc.c file to the project (it should be listed in the Source Files folder on the left in avr studio).
that was the problem, it compiles ok now!
thanks a lot and keep it up!
