Array manipulation.
13 posts / 0 new
I want to manipulate some array type variables.
char first[6] = {"01234"};
char second[6] = {"56789"};
char *third;
char third = malloc(11);
strcpy(third,first);
strcat(third,second);
It's simple. Right after strcpy, on variable "third" i've got "01234". And after strcat, on variable "third" i've got "0123456789".
but i want to do something like this:
strinsert(third,second,3);
So the result on variable "third" will be "0125678934". is there any default function to do this?
KISS - Keep It Simple Stupid!
AFAIK, there is no such standard function. You'll have to write those (few) lines yourself.
:shock:
Oh my..
Ok then I'll wrote it..
Just sketching, not sure about missing +1's and such on indexes, but something like this maybe? :
char * strinsert(char * s1, char * s2, int insertpos)
   char * result = malloc(strlen(s1) + strlen(s2) + 1);
   strncpy(result, s1, insertpos);
   strcat(result + strlen(result), s2);
   strcat(result + strlen(result), s1 + insertpos);
Johan gave you a good outline sketch. However, not that I'm cautious or anything...
but I wouldn't use malloc() inside a function that doesn't also free() the memory. Use malloc in the calling function and pass the value to strinsert. Or, better still, don't use malloc() at all!
I guess the "unseen" bit of John's solution is where he strcpy()'s 'result' back to 's1' then free()s 'result'?
(the worrying thing here is that 's1' must have been allocated before the call large enough to accomodate both strings - I think I'd insist on the sizeof(s1) also being passed in and used for the malloc of the working copy and wrok being done to truncate stuff if the combined solution won't fit)
Yeah, I know. While walking the dog this evening I suddenly realised that I didn't return the result. Dog-walking can have strange spin-offs...
As the OP seketched a malloc without a free, so did I. From OPs sketch it looked as though he didn't want any of the two original strings destroyed, so my intention was to return a pointer to the malloced string. I have no major problem with making a malloc in the function without a free as long as this is clearly documented.
For maybe faster, and smaller, code one could do it all with a few for loops instead of calling strcpy/strcat (of course).
pretty dangerous coding style.
Better safe than sorry. Malloc of small hunks is bad form on a small-RAM micro. Causes a cluttered mess of non-contatenated free()'d blocks after some time.
if these strings are to be UART'd or LCD'd, better to use printf() formats to do this stuff. Or sprintf() for destination = ram.
Steve,
I know Joerg has stronger views on this but if this were the only malloc/free being used then fragmentation would not occur. It's when things remain malloc'd then other malloc's occur before the first is freed that the heap might begin to fragment.
Cliff
Oh, all right then...
char * strinsert(char * s1, char * s2, int insertpos, char * result)
   return result;
:wink: : Now let's argue over if the result value should go as the last parameter or if it rather should be
char * strinsert(char * result, char * s1, char * s2, int insertpos)
to follow the scheme of the standard strwhatever functions.
The buffer overrun is arguably a much more dangerous condition than heap frag. Consider including the buffer length as a parameter.
C: i = "told you so";
Gee thanks for all your input. I didn't expect many replies like these since i've written my own function that looks similar to Johan's, but then i changed my own code to for-loop style for a better size. Yes it is smaller. Don't know why, but it works.
Thanks.
The answer could be found by studying the generated assembler, but I suspect part of it will be because you got rid of a bunch of function calls.
