yet another program memory question
15 posts / 0 new
Hi, I had a look through the forums, but didn't find an answer to this one.
Sometimes I like to copy some data directly into ram, without having to give it a name. ie.
char buffer[10];
memcpy(buffer, (char[]){1, 2, 3, 4, 5, 6}, 6);
This works fine, but I want to source the data from program memory to save ram. I thought this would work:
memcpy_P(buffer, (prog_char[]){1, 2, 3, 4, 5, 6}, 6);
but this just puts junk into the buffer.
I also tried this one:
memcpy_P(buffer, (const PROGMEM char[]){1, 2, 3, 4, 5, 6}, 6);
but this actually causes the compiler to crash, and asks me to submit a full bug report, which I don't really want to do.
Does somebody know how I can do this?
I basically want something like PSTR() only using a list of literals instead of a string.
Regards
, Michael.
Telling yourself something is too hard, or too complicated, is not a determination. It is a decision.
Have you read the thread on the PROGMEM attribute in the tutorials forum?
Steve A.
Yep.
Pulling data out from program memory space must use pgm_read_byte(&yourconst);
maybe simple like this:
const char yourconst[10] PROGMEM = {1,2,3,4,5,6};
char[10] buffer = {0};
void main()
    uint8_t i=0;
    while(i<6)
        buffer[i]=pgm_read_byte(yourconst[i++]);
KISS - Keep It Simple Stupid!
Gotta ask - what's the issue with simply naming the data?
#include
#include
prog_uint8_t my_data[]= {1,2,3,4,5,6};
int main(){
    uint8_t buffer[10];
    memcpy_P(buffer,&my_data,6);
    while(1);
If one can't think of a good name for it,
one can still avoid the sniggers that might be induced by calling it fred.
The casting cannot change the storage class of the array, it just changes the way others see it. Following the same scheme used in PSTR definition:
#define PDATA(type, ...) (__extension__({static type __nonamed[] PROGMEM = __VA_ARGS__ ; &__nonamed[0];}))
memcpy_P(buffer, PDATA(int, {1, 2, 3, 4, 5, 6}), 6 * sizeof(int));
Best regards,
Carlos.
I thought all programmers used the internationally recognised 'foo' and 'bar' in fact? ;)
OT:
I thought all programmers used the internationally recognised 'foo' and 'bar' in fact? Wink
Not FORTRAN programmers. They largely depend on the fact that anything named i,jk,l,m or n is an INTEGER by default. All others are REAL (or was that FLOAT?). That's all they think they need. Their mantra goes:
"If you can't do it in FORTRAN, then do it in assembler. If you can't do it in assembler, then its not worth doing"
carloslamas wrote:
Best regards,
Carlos.
Carlos!! you are a valuable man!!!
Thanks for your explanation and solution.
You are a true master of the squiggly brackets and underscores!
If anyone is still interested, in the meantime I have been doing this:
memcpy_P(tempbuf,PSTR("\x08\x03\x1A\x03\x05\x00\xFF"),7);
Which works, but it's not as nice.
I will use Carlos's PDATA define now.
Regards, Michael.
Hei, i don't know this kind of identifier... prog_uint8_t, what does it mean? is it mean something like uint8_t PROGMEM?
I don't understand this, especially typedef part:
typedef uint8_t PROGMEM prog_uint8_t;
Code:
And Google didn't give any hits for "typedef in C"? You're on the internet, obviously. Please learn how to make use of it.
You could read the above type definition as "define a new type called prog_uint8_t to be equivalent to uint8_t PROGMEM".
hm..i think i'm getting freak here. For a whole day i just open www.avrfreak.net on my browser and now i started to think that internet is www.avrfreak.net.
I should Google it first before asking..
JohanEkdahl wrote:
OT:
fred is on the list too, but rather far down.
Python programmers live elsewhere.
I once had the joy of reading a FORTRAN program by someone
who apparently believed in neither FORTRAN nor assembler.
His variables consisted of two arrays, one for INTEGER and one for REAL.
This one suspects he would have preferred programming in machine.
