delay problem attiny 2313
15 posts / 0 new
hello,
i have a problem with my C code :
#include
#include
#include
#include
void init()
  DDRD = (1<<PD5); // PORTB PB0-PB6 als uitgang
  DDRB |= (1<<PB2)|(1<<PB3)|(1<<PB4); // PB0 en 1 als ingang, PB2 tot 4 als uitgang
  DDRB |= (PB0<<1)|(PB1<<1);
int main()
	switch( PCINT0)
		case (1):
			switch (PCINT1)
				case (1):
				PB4 == 1;
  				PB3 == 0;
  				PB2 == 0;
  				PD5 == 0;
				_delay_ms(1);
				break;
				case (0):
				PB4 == 1;
  				PB3 == 0;
  				PB2 == 1;
  				PD5 == 0;
				_delay_ms(1);
				break;
				default:
				break;
		break;
		case (0):
			switch (PCINT1)
				case (1):
				PB4 == 0;
  				PB3 == 1;
  				PB2 == 1;
  				PD5 == 0;
				_delay_ms(1);
				break;
				case (0):
				PB4 == 1;
  				PB3 == 0;
  				PB2 == 0;
  				PD5 == 1;
				_delay_ms(1);
				break;
				default:
				break;
			break;
		default:
		break;
It is for a controlling a robot.
PB2 - 4 and PD5 are outputs
But there seems to be a problem wit the _delay_ms(1);
When I try to place the program in my attiny 2313 then i get a message : The contents of the hex file doesn't fit in de device.
When i leave thouse delays out of my program than it goes perfect.
Mathias Deneire
newby
Did this require the use of compiler optimizations -Os or the like? I bet your current setup understands the 1 as floating point number which it has to convert to integer, so it includes floating point libraries.
Basically I just use _delay_loop1 and _delay_loop2 macros instead of delay_ms because of its oddities and I am no longer familiar what it really does, as the new avr-libc versions have more wrappers to how delay_ms really uses _delay_loops to get over the limitations.
- Jani
Edit: And besides, all those lines with == are wrong, I think you want just one =
Edit2: And if you really use avr-gcc, I think even PB5=0; does not do what you want. You can't control single bits like this, just use |= and &=~ in some macros.
- Jani
its already updated :
#include
#include
#define F_CPU 1000000UL
#include
void init()
  //DDRB |= ~(1<<PB0)|~(1<<PB1);
int main()
	switch( PB0)
		case (1):
			switch (PB1)
				case (1):
				PORTB |= (1 << PB4);
  				PORTB |= ~(1 << PB3);
				PORTB |= ~(1 << PB2);
  				PORTD |= ~(1 << PD5);
				_delay_ms(500);
				break;
				case (0):
				PORTB |= (1 << PB2);
				_delay_ms(500);
				break;
				default:
				break;
		break;
		case (0):
			switch (PB1)
				case (1):
  				PORTD |= (1 << PD5);
				_delay_ms(500);
				break;
				case (0):
				_delay_ms(500);
				break;
				default:
				break;
			break;
		default:
		break;
but still i have the same mistake
Some remarks,
The routine void init() is not called in your main loop.
as far as I can see your program crashes after its first switch statement. goes back to reset and starts all over.
If I remember correctly the delay_ms routen only can go to 255. Check the compiler library to see what the max allowed value is for delay_ms.
regards
Well that actually depends on your WinAVR version. Most have a catch all while(1) beyond main() but there was a version where this was not present and a return from main() did indeed lead off into rogue code and an eventual reset. FAQ#2 below.
BTW the very latest _delay_ms() breaks the former limitation on parameter usage - though the granularity suffers beyond a certain point.
Cliff
Yes you do - it still does not do what you want.
You set bits with or operator |=, you clear bits by anding the inverted mask &=~ .
Therefore, the quoted line would leave PB3 as it were, and would set all other bits in port B.
- Jani
   switch( PCINT0)
      case (1):
         switch (PCINT1)
   switch( PB0)
      case (1):
         switch (PB1)
PCINT0 and PCINT0 are constants. Switching on them will accomplish nothing. The same goes for PB0 and PB1. The only code that is being run at all is case 0 in the outer switch, and case 1 in the inner switch.
Aside from that, your code would only run through once anyways and then exit main (something that you should never do). And you have a nice init function that you never call.
Steve A.
#include
#include
#include
unsigned char pin;
void init()
  DDRB |= (1<<PB2)|(1<<PB3)|(1<<PB4)|(1<<PB5); // PB0 en 1 als ingang, PB2 tot 4 als uitgang
int main()
  init();
  pin = PINB;
  if (pin &((1<<PB0)&&(1<<PB1)))
  	  PORTB &= ~(1 << PB3);
	  PORTB &= ~(1 << PB2);
  	  PORTB &= ~(1 << PB5);
	  _delay_ms(1000);
   if (pin &(1<<PB0))
	  _delay_ms(1000);
   if (pin &(1<<PB1))
  	  PORTB |= (1 << PB5);
	  _delay_ms(1000);
  if (pin &(~(1<<PB0)&&~(1<<PB1)))
	  PORTB &= ~(1 << PB4);
  	  PORTB |= (1 << PB3);
	  _delay_ms(1000);
i've changed the program, but i can't read notting in,
hope some of you guys know a sollution :D :D
I'm not that super in C code, but
I have a suspicious feeling that it should be :
pin &&((1<<PB0)&(1<<PB1))
as far as i'm correct this means that both PB0 AND PB1 have to be set in pin (that is pinB )
I might be mistaking though as I'm not very experienced in C code.
Another thing is that you still don't have an infinite loop in your main routine. Wich can cause unexpected behaviour.
also the init can be the following line if your comments hold. (for the english readers the comments state that PB0 & PB1 should be input, all other pins in portB are output)
DDRB = ~((1<<PB1)|(1<<PB0))
this first sets pb1&0 high (wich normally is output) to then invert it and thus making every pin output except pb0&1
In addition I would like to know if your code now fitting in the device.
regards
i've i were you, usually i use this macro to detect logic on PB0 and PB1 :
if ((bit_is_set(pin,PB0))&&(bit_is_set(pin,PB1)))
to gain a readable code...
but for C compatibility issue, I use this:
if(pin&((1<<PB0)|(1<<PB1))==((1<<PB0)|(1<<PB1)))
& = AND operation
| = OR operation
&& = logical AND test
|| = logical OR test
use brackets to determine priorities.
please read delay.h
your _delay_ms(1000); won't work well. It will work in good way only under 262ms per MHz.
KISS - Keep It Simple Stupid!
That old limit no longer exists in the most recent avr-libc, see:
Ooops. I've should read that.
There is statement
"When the user request delay which exceed the maximum possible one, _delay_ms() provides a decreased resolution functionality."
I don't understand the meaning of decreased resolution. What is the effect of decreased resolution?
This is how it has changed. Previous version:
void
_delay_ms(double __ms)
	uint16_t __ticks;
	double __tmp = ((F_CPU) / 4e3) * __ms;
	if (__tmp < 1.0)
		__ticks = 1;
	else if (__tmp > 65535)
		__ticks = 0;	/* i.e. 65536 */
		__ticks = (uint16_t)__tmp;
	_delay_loop_2(__ticks);
New version - notice how large values are in 0.1ms increments:
void
	uint16_t __ticks;
	if (__tmp < 1.0)
		__ticks = 1;
		//	__ticks = requested delay in 1/10 ms
		__ticks = (uint16_t) (__ms * 10.0);
		while(__ticks)
			// wait 1/10 ms
			_delay_loop_2(((F_CPU) / 4e3) / 10);
			__ticks --;
		return;
I'm still not sure of the point of this program is. It will read PINB once, do one of the 4 if's (that is, if you correct your conditions to do what you really want it to do), then exit.
Steve A.
euhm, yes, your right
#include
#include
#include
void init()
int main()
 init();
   if ((bit_is_set(PINB, PINB1)) && (bit_is_clear(PINB, PINB0)))
	  	_delay_ms(1000);
   if ((bit_is_set(PINB, PINB0)) && (bit_is_clear(PINB, PINB1)))
	  	_delay_ms(1000);
  if ((bit_is_clear(PINB, PINB0)) && (bit_is_clear(PINB, PINB1)))
	  _delay_ms(1000);
It works fine for leds :p but not with a motor, i'll need to find an other way
