libpng
5 posts / 0 new
Where do I obtain libpng for avr32-linux for cross-compiling under Ubuntu (Gusty)
Some while ago...
hce wrote:
zlib (libz) libpng and libjpeg
These libraries are provided by the atmel repository, and are installed with apt or synaptic. /etc/apt/sources.list should have this line: deb http://www.atmel.no/beta_ware/av... binary/
However, this location is no longer available (gives 430 Forbidden). Is there a new location for this?
Hey,
try buildroot
http://www.atmel.no/buildroot/
sjb,
you cannot call this location directly, you have to add this line to the file /etc/apt/sources.list. Be sure to update all with the command: sudo apt-get update. Then you can install the lib with the command sudo apt-get libpng-avr32.
Frank
fwuerri: Okay, Thank you. I had not realised that. I had assumed I could browse the location . I tried to browse because I actually need the version for Gusty, not Breezy.
Does anyone know the URL to use for Gusty? Or should I just guess using the obvious substitution :wink:
I run gutsy too and the location works fine. Try it.
Frank
