A simpler expression?
11 posts / 0 new
((PINA & (1<<3))>0)
I've read through the tutorial in the forum about bitwise operations but I'm still a little confused. I know what the above code does. It gets the value (1 or 0) of the third pin in PORTA. I know that the comparison is redundant for a conditional statment (Any value other than 0 is true) but that isn't why I wrote that code. Is this the most efficient way of getting the value of the PIN or is there another way? Thank you for your advice.
Not sure why you feel the need for the >0 comparison in there? Are you just using this in an if() statement:
if ((PINA & (1<<3))>0) {
in that case:
if (PINA & (1<<3)) {
works as well on the basis that 0 is false. Sure, when the bit is set PINA & (1<<3) will have the numerical value 8 in fact - but that isn't 0 so it's considered true.
If however you were using:
x = ((PINA & (1<<3))>0);
where you wanted x to hold just 0 or 1 then
x = (PINA & (1<<3));
would not work, it'd be 0 or 8. But you could use:
x = (PINA & (1<<3)) ? 1 : 0;
Cliff
Essentially, this is my first guess at trying to flip an eight bit number which just so happens the signals coming in from PORTA. Logically, I should have wired it the right way but it was essentially a compromise between simple code or neater routing. I choose neater routing while also forgetting that bitwise shifting does not wrap around.
You mean you are trying to flip 11011000 so it becomes 00011011 ? This has come up MANY MANY times here and the algorithms for bit flipping are well known. Doing multiple if()'s is not the "best" solution. I like the one that involves the 55's and AA's myself.
Wonder what "flip byte" yields in search?
Cliff
EDIT: Just one of the many threads:
Why do you keep on assuming that I was using multiple if()'s? I'm wrote more inept code than that.:)
Sorry but given the limited amount of info in your post I ASSUMED (incorrectly it seems) that your:
((PINA & (1<<3))>0)
was being used in a logical expression. Presumably it's actually in an assignment then?
Anyway, I've given you a link to an overall (good) solution to the bit flipping thing - your choice whether you use it or ignore it I guess.
((PINA & (1<<3))>0)
I just realized the idiocy of what I was doing. In my process of creating a bitmask I didn't realize that five steps later I created the same bitmask. It was one of those days yesterday. I asked the lady at the store if she had any cat stuffed animals and she walks up and points to the tiger right in front of me.
((PIN & (1<<PINNUMBER)>0)>>PROPERPOSITION)
You did read that link I gave didn't you? - there are FAR easier ways to flip bits given there.
I did. That code was what I was doing before. Im working on the simpler solution right now.
if you have plenty of room to waste, and you need to do many bit-flippings, you could use a table...
char mirror[256] = {0x00, 0x80, 0x40, 0xc0, 0x20, 0xa0, ... };
conv = mirror[etyb];
-That is simple, it's fast, but it... wastes space.
There are lots of simple solutions in the thread Cliff referred to.
A little modification to one in that thread (assuming only needed for porta)-
uint8_t get_porta(void){
    uint8_t temp=PINA;
    temp=((temp>>1)&0x55)|((temp<<1)&0xaa);
    temp=((temp>>2)&0x33)|((temp<<2)&0xcc);
    asm volatile("swap %0":"=r"(temp):"0"(temp));
    return temp;
//18 words
//usage- my_var=get_porta();
or if those pin mappings are not actually reversed, but are 'mixed up'
    uint8_t temp=PINA;
    uint8_t retval=0;
    //actual pin here       'virtual' pin here
    if(temp&(1<<PIN0)) retval |= (1<<PIN5);
    if(temp&(1<<PIN1)) retval |= (1<<PIN3);
    if(temp&(1<<PIN2)) retval |= (1<<PIN1);
    if(temp&(1<<PIN3)) retval |= (1<<PIN0);
    if(temp&(1<<PIN4)) retval |= (1<<PIN7);
    if(temp&(1<<PIN5)) retval |= (1<<PIN2);
    if(temp&(1<<PIN6)) retval |= (1<<PIN4);
    if(temp&(1<<PIN7)) retval |= (1<<PIN6);
    return retval;
//22 words
