extra vectors
2 posts / 0 new
When looking at the .inc files I notice that the m8535def.inc has 21 interrupts defined and the AT90S8535.xml file shows only 17. The "extra" ones seem to be
.equ TWIaddr =$011 ;Irq. vector address for Two-Wire Interface
.equ I2Caddr =$011 ; Irq. vector address for Inter Intergrated Circuit interface
.equ INT2addr=$012 ;External Interrupt2 Vector Address
.equ OC0addr =$013 ;Output Compare0 Interrupt Vector Address
.equ SPMRaddr=$014 ;Store Program Memory Ready Interrupt Vector
these, as the .xml file in part description doesn't go higher than $010. I am wanting to use these files to generate asm code, but if they are weird, I am then kinda stuck. Any ideas what is going on?
Tall Daniel
admin's test signature
What's going on is that the m8535def.inc is for the ATmega8535 and the AT90S8535.xml is for the AT90S8535, which is a different device. The include file for the latter is called 8535def.inc
-Geir
