LED Flash Issue
23 posts / 0 new
Hi guys, Im continuing on a project started by someone else and having a few issues just debugging to see where the code gets up to.
I'm using a Mega8-16 with AVRISP2 in conjunction with AVRStudio.
I've hooked up an LED to PortD and when I run a basic LED flash program everything is fine (5V at PD7 with the LED flashing once). eg.
DDRD = 0xff;
PORTD |= (1 << PD7);
_delay_ms(4000);
PORTD &= ~(1 << PD7);
However when I insert this code into the main function of the existing program (not forgetting to import and ), I only get about 1.3V at the pin and the LED doesn't switch on and then after 4 seconds the pin doesn't change to 0V as expected.
Any ideas?
You need 2 delays. Do you have a current limit resistor in series with the led?
Yes there is ~500R limiting the current. I have also tried:
DDRD = 0xff;
_delay_ms(4000);
_delay_ms(4000);
But same story, the pin stays at 1.3V and doesn't go down to 0V then back high as expected.
DDRD = 0xff;
_delay_ms(4000);
_delay_ms(4000);
Don't need the last line as the code should loop up.
But where is the rest of your code? ie the for( ;; ) or while (1) for the loop.
Also I'm not sure if delay_ms can go that high. I think the latest winAvr can now do it?? but previously it was limited to a max of 200 something ms/clock. Have a read of that part of the docs for delay_ms.
Which chip are you using?
The working test program I used to flash the LED is:
#include
#include
    DDRD |= (1 << 7);
    // Blink
    _delay_ms(400);
    _delay_ms(4000);
    return 1;
The program above works with no problems but as soon as I copy the code into the full program which I am debugging, the issue outlined in the first post arises. I've also tried _delay_ms(400) to no avail. The program uses 30kHz and 8kHz ISRs which may be causing the issue, but being a newbie I'm still just trying to figure out how they function. :)
I am using the ATMega8-16PU DIP-28
PD7 is also the analog comparator. Is any code accidentally turning that on?
Also the above program in standalone mode will crash, I believe, as it has nowhere to return to.ie most likely hang at the last line or restart from the beginning. Not sure if GCC handles that properly.
This loops always.
#include
#include
    DDRD |= (1 << PD7);
    for( ;; )
    // Blink
    _delay_ms(4000); 		//Max 6.5535 seconds with latest winAvr
    _delay_ms(4000);
Of course the ISR if not done properly will cause a lot of problems too.
Whoa - JS helping out on a C question - a miracle has happened! :D
The poor OP has no chance of solving his problem now!! :evil:
Today a flashing led...tomorrow ze vorld...
Definetely a bad case of Clawson-ites here...
I managed to partially solve the problem, the code im debugging already had the ports and pins defined with specific names in the header, so using the defined names works. Now I can switch an LED on to see where the code runs until although it switches on and stays on not giving me a single flash like I want.
//////LED DEBUG------------
	LED1_PORT |= LED1A;
	msDelay(10);
	LED1_PORT &= ~LED1A;
	msDelay(10);
Yeah John, WTF
I thought you and I were the only assembly-only folks left.
WEll I did admit I may have to sit down and learn 'c' at the ripe old age of 39.
If Dean opens his mouth I will fly to australia and sick a kangaroo up his Buttloader :lol:
Ok, now back to the OP
Has your issue resolved?
If Dean opens his mouth I will fly to australia and sick a kangaroo up his Buttloader Laughing
I do love the C language, but I think I'll keep my mouth shut on this occasion...
- Dean :twisted:
How is LED1A defined??
Have you tried
  LED1_PORT |= 1<<LED1A;
   msDelay(10);
   LED1_PORT &= ~1<<LED1A;
   msDelay(10);
(I could show off with _BV ... and why aren't the C gurus helping??)
js, LED1A is defined as:
#define LED1A (1 << PD7)
I tried the code you suggested but I did't get anything. The LED just stayed off.
hmmmm 10mS is prety fast. Tried a few hundred ms?
So, with all the time you spend debugging, you could have got a partime job and earn the 50 bucks for a Dragon and changed the chip to a M88, then you could have had debugWire facility :)
Does your real application actually define PD7 somewhere as output? - just to make sure.
...and does the code actually get to the point where it is supposed to flash in the larger program?
So, with all the time you spend debugging, you could have got a partime job and earn the 50 bucks for a Dragon and changed the chip to a M88, then you could have had debugWire facility Smile
Without a doubt, and carton of beer for the weekend. Coming from only working with HC12s to AVRs I never anticipated that something so simple would have me stumped for so long.
I've checked that PD7 is set to output in the code and through the debugger just to be sure.
Does anyone have a simple LED flash program that they know works on an ATmega8?
You do realize that the analog comparator is enabled by default, don't you? Now, you'll have to check whether that does an override on port direction like some of the peripherals.
We still haven't seen the complete "new" program.
Which way is the led connected to the pin?
Between Vcc and pin or between pin and GND?
This is to ask which way lits the led: setting or clearing the bit.
Debugging is for sissies and delivery for surgeons. Real men do demonstration.
6th post down??
Fixed.
ACSR |= (1 << 7); // Disable analog comparator
_delay_ms(50);
_delay_ms(500);
That did the trick. Thanks everyone
Wasn't this one of the early things I said? :)
Good point js, I assumed that it was off by default. But strangely removing that line doesnt seem to make a difference, it works the same. Thanks a bundle for your help.
