I2C
6 posts / 0 new
How might I communicate to a I2C sensor using a attiny2313 or a atmega8?
Life Is Like A Bucket Of Chicken.
USI
C. H.
It's only waste if you don't use it!
The ATmega8 has a TWI module. The ATtiny2313 has the USI. Personally I would go for the ATmega88 rather than the ATmega8.
Is there any info or a data sheet on the TWI or USI?
The data sheets for the processors are located on this page:
http://www.atmel.com/dyn/product...
The application notes are located on this page:
TWI is a I2C compatible hardware module that requires less CPU support to run. USI is a hardware module that can be I2C compatible, but it requires allot of more software and direct support from the CPU resources to run.
The application notes also have example programs.
Thank you,
A very useful data.
