2's complement in assembly?
19 posts / 0 new
Can anyone suggest the correct way to calculate the two's complement from a 16-bit number stored in the ALU?
com r24
com r25
adiw r24, 1
Is one way, but that takes 4 cycles to complete, and uses adiw, which is not available in all devices.
I saw somewhere that it is possible to use
com r25
neg r24
I thought this can't be true... And it wasn't. Can anyone suggest another algorithm which would complete in 3 cycles, or take less space?
axos88
axos88
If you kept an 0x00 and an 0x01 in a register pair, you could use a register to register add as the increment instead of the add immediate.
That would fix the compatibility issue, but it wouldn't produce faster nor smaller code... (+1 words)
axos88
this generated the following that uses COM;NEG
plus a SBCI, so back to 3 instructions it seems. But only 3 cycles instead of 4.
HA? what happened to cliff's post???
I'm sorry, I don't quite follow... what generated what?
axos88
Something happened here. It looks likes several posts have gone missing.
Steve A.
Yeah, last time i wanted to open the topic it said it didn't exist...
axos88
Cliff had some compiled C code which has disappeared.
From memory:
com r25
neg r24
sbci r25,0xff
right, thanks... that seems to be the best way to do it... and that can be generalized for n words (well uh.. bytes) as well.
axos88
Sorry to dredge up an old thread.
I'm assuming this works because NEG creates a carry unless the result is zero?
So for a three-byte number r25:r23 (big endian):
com r25
com r24
neg r23
sbci r24,0xff
sbci r25,0xff
I think it works on paper, but am I completely up the creek?
It's me again...
Well, from this old thread, I noticed they compiled something to see how the compiler did it.
So, I compiled this:
int main() {
	uint32_t test = PORTB;
	uint32_t temp = -test;
	return temp + (temp >> 16);
and the output is (I separated the relevant code for clarity):
0000007a <main>:
  7a:   85 b1           in      r24, 0x05       ; 5
  7c:   90 e0           ldi     r25, 0x00       ; 0
  7e:   b0 e0           ldi     r27, 0x00       ; 0
  80:   a0 e0           ldi     r26, 0x00       ; 0
  82:   b0 95           com     r27
  84:   a0 95           com     r26
  86:   90 95           com     r25
  88:   81 95           neg     r24
  8a:   9f 4f           sbci    r25, 0xFF       ; 255
  8c:   af 4f           sbci    r26, 0xFF       ; 255
  8e:   bf 4f           sbci    r27, 0xFF       ; 255
  90:   ad 01           movw    r20, r26
  92:   66 27           eor     r22, r22
  94:   77 27           eor     r23, r23
  96:   84 0f           add     r24, r20
  98:   95 1f           adc     r25, r21
  9a:   08 95           ret
Therefore, if this is the code for 32 bit, I'm pretty sure for 24 bits it's the code you wrote.
 It really hurt my eyes to use uint32_t for signed calculations ;)
Many thanks, much appreciated.
No excuse not to move on to the next hard bit now...
It's me again...
big endian
Why?  The AVR is arguably a little-endian machine.  Are you writing some kind of cross compiler?  Or an interchange library à la Google's protobuf?
joeymorin wrote:
big endian
Calm down, just meant to type little... :-)
It's me again...
Stub_Mandrel wrote:
Calm down,
In what way was Joey's reply not "calm" ? I think you may be the one over-reacting here.
clawson wrote:
Stub_Mandrel wrote:
Calm down,
I assume you responded before I added the smiley...?
It's me again...
avr-gcc uses
neg HI
neg LO
sbc HI, __zero_reg__
as the compiler maintains a register that is known to be 0.  When such a reg is not available, you can constrain to the upper 16 regs using
com HI
neg LO
sbci HI,-1
(which is what older compiler versions used to use).
SprinterSB wrote:
avr-gcc uses
neg HI
neg LO
com HI
neg LO
sbci HI,-1
Interesting, thanks.
It's me again...
