KAVRCalc 1.9 Released
6 posts / 0 new
I released version 1.9 of KAVRCalc today. From the ChangeLog:
Version 1.9 (Feb 5, 2008)
  - Center application on screen
  - Use tabbed layout
  - Add TWI calculator
  - Add a common clock frequency to popup list
  - New computed values display for better compatibility with themes
  - Change save file format to XML
  - Fix off-by-one bug in CTC calculator
Hi, Kevin:
Where can I download it to test? May I search for the testing thread? ;)
Guillem.
Kevin,
I still have the same problem as before, namely, the Timer tab is just too tall, and I can't resize it. By the way, I am using linux:-)
Cheers,
Zoltan
Impressive job, Kevin. I will try to check it more extensively (under Win SP).
Guillem.
Zoltan: thanks for the feedback. I make the timer layout more horizontal and less vertical in the next release.
Guillem: Thanks, please do beat on it and let me know if your devilish torture can crash it!
