Atmel studio Error
8 posts / 0 new
I have created the atmel start project long back and working , now i need to add the software component to existing project , if i am adding other software component i am getting error like this :
unspecified error (Exception from HRESULT : 0x80004005(E - FAIL)) in the prompt
How to resolve this problem
Megha
You need to give a more detailed description of what, exactly, you are doing when this happens.
List the steps to reproduce the issue.
What do you mean, "like"?
What do you mean, "in the prompt"?
See Tip #1 for how to post screen shots
I have the same issue. Working  and proven Atmel Studio 7 project. From within Atmel Studio go to: "Project - re-configure Atmel Start Project"
I now make some changes within Atmel Start, e.g. re-configure timer settings and port pin configuration. When I finally select "Generate Project - Project Summary, select files modified - OK " I immediately get the same error message, nothing is downloaded.
Any ideas how to recover other than starting over with a new project? I do not suppose that it is a problem of Atmel Start collecting the necessary files (which normally takes some time) since the error message appears immediately without delay.
Drei I am having the same issue did you figure out a way to solve that if so could you let me know
You can always reconfigure it from  https://start.atmel.com/ and then get the atzip into the IDE.
I faced the same issue.
I solved it like this:
Try closing other solutions if you have some open and also try closing other tabbed windows other than atmel Start (project windows, source files etc.)
That helped. Closing all the other windows except the Atmel start resolved it. Thanks for your help.
Sheik Rahman
This may link some people too: https://developercommunity.visua...
