Attiny414 UART wrong character
19 posts / 0 new
All settings are correct. Still the characters are wrong.
#define F_CPU 20000000UL
#define BAUD_RATE 9600
#define BAUD_PRESCALE ((64UL * F_CPU)/(16UL * BAUD_RATE))
#include <atmel_start.h>
#include <main.h>
#include <avr/wdt.h>
#include <string.h>
#include <util/delay.h>
#include <avr/interrupt.h>
Usart Usart_;
Usart::Usart(){
    PORTMUX.CTRLB = PORTMUX_USART0_ALTERNATE_gc;
    USART_TX_set_dir(PORT_DIR_OUT);
    USART_TX_set_level(HIGH);
    TRIGGER_set_dir(PORT_DIR_IN);
    USART0.BAUD  = (uint16_t)BAUD_PRESCALE;
    USART0.CTRLC = USART_CMODE_ASYNCHRONOUS_gc |
                    USART_CHSIZE_8BIT_gc |
                    USART_SBMODE_1BIT_gc |
                    USART_PMODE_DISABLED_gc;
    USART0.CTRLB = USART_RXEN_bm | USART_TXEN_bm;
    USART0.CTRLA = 0;
void Usart::Transmit(unsigned char Tx_Data){
    while(!(USART0.STATUS & USART_DREIF_bm)){;};
    USART0.TXDATAL = Tx_Data;
unsigned char Usart::Receive(void){
    while(!(USART0.STATUS & USART_RXCIF_bm)){;};
    return USART0.RXDATAL;
int main(){
    atmel_start_init();     // Initializes MCU, drivers and middleware
    Usart();
    while(1){
        Usart_.Transmit('A');
        _delay_ms(500);
    return 0;
How do you know that your AVR is running at 20MHz?
Following the datasheet ATtiny214/414/814 CPU is running 20 MHz
I'm going to go way out on a limb here and assume (without downloading and studying hours of documentation on the Tiny414) that    USART0.BAUD  =  is the way to program the baud rate and that to get 9600 baud, you would use:    USART0.BAUD  = 9600;     If this is not the case, please let me know.
  If it is true then you have a wrong formula because I get about 8000 every time that I work the unusual formula (i.e.  64* Fosc ect...) that the code is using.  This is close enough to 9600 to give the observed problem behavior: constant wrong chars on UART input.
With 9600, it doesn't work either.If I want 9600 baud rate, you have to calculate it for the register.
So, somewhere, you've turned off the divide by 6 prescaler?
Try adding this line.
If this helps, you have your clock settings wrong.
    Usart();
    _PROTECTED_WRITE(CLKCTRL.MCLKCTRLB, 0);  // ADD LINE
    while(1){
        _delay_ms(500);
Yes F_CPU by default is 20MHz. By default F_PER is divided by a factor of 6 i.e 20MHz/6=3.3MHz. So add one more line and correct the baud rate formula as highlighted, in you program as below
#define F_PER 3333333UL
#define BAUD_PRESCALE (((64UL * F_PER)/(16UL * BAUD_RATE))+0.5)
With these settings, it doesn't work either
Why do so many simple mistakes happen?
#define F_PER 3333333UL // wrong
#define F_CPU 3333333UL // correct
good bye
#define F_CPU 3333333UL also wrong
This is working code for my ATmega328p. For the Attiny414 I followed the same principles with the datasheet.
#define F_CPU 16000000UL // Default clock speed
#define BAUD 9600
#define MYUBRR (F_CPU/16/BAUD-1)
#include <stdio.h>
unsigned char USART_Receive(void){
    while(!(UCSR0A & (1<<RXC0))){;}
    return UDR0;
void USART_Transmit(unsigned char data){
    while(!(UCSR0A & (1<<UDRE0))){;}
    UDR0 = data;
void USART_Init(unsigned int ubrr){
    UBRR0H = (unsigned char)(ubrr>>8);
    UBRR0L = (unsigned char)ubrr;
    UCSR0B = (1<<RXEN0)|(1<<TXEN0);
    UCSR0C = (3<<UCSZ00);
int main(void){
    USART_Init(MYUBRR);
    sei();
        while(1){
            unsigned char Rx_data;
            Rx_data = USART_Receive();
            USART_Transmit(Rx_data);  //echo
https://ww1.microchip.com/downlo...
#include <string.h>
void USART0_sendString(const char *str)
  for(size_t i = 0; i < strlen(str); i++)
    USART0.TXDATAL = str[i];
  PORTB.DIRSET = PIN2_bm;            // USART TxD pin
  USART0.BAUD = 1389;                // 9600 @ 3.33MHz
  USART0.CTRLB = USART_TXEN_bm;      // enable Transmitter
    USART0_sendString("Hello World!\r\n");
    _delay_ms(1000);
The truth is more important than the facts. (Frank Lloyd Wright / Unsourced)
It's probably the terminal. I get the correct character with the oscilloscope
Timing errors hardly seem likely, if it is on the PC--the timebase should be on the money.  Of course, it could be cabling/connections, or are the terminal setting suspect?  Obviously the correct baush/start/stop needs set properly.
The terminal might have some trouble keeping up if you are pumping out chars with no time gap whatsoever.  Bray's gulps a bit if you set it to stream hex values in addition to the ASCII.
AVR USART TxD
Are you saying the answer in #7 did NOT work?
What’s the interface to the pc?  A USB to ttl cable (w/ leads for TX,RX, GND)?  or a USB to RS232 (w/ DE9 connector)?
hint the DE9 connector will not work without  RS-232 converter on your AVR RX/TX pins!
jim
FF = PI > S.E.T
DE9 connector cable was defect. That was the problem
