How to initialize and read DS1621? Solved
4 posts / 0 new
Hi all!
I have a project in which the DS1621 is connected via the i2c bus.
Device emulated in Proteus. In the i2c debugger, I see that the temperature value is not correctly transmitted in response to the request.
My DS1621 initialization and reading code looks like this:
// Адрес устройства
#define DS1621_ADR_R	0x91
#define DS1621_ADR_W	0x90
// Адреса регистров
#define DS1621_READ_TEMPR		0xAA	// Адрес регистра reads temperature
#define DS1621_READ_COUNTER		0xA8	// Адрес регистра reads the value Count_Remain
#define DS1621_RAED_SLOPE		0xA9	// Адрес регистра reads the value Count_Per_C
#define DS1621_START_CONVERT	0xEE	// Адрес регистра begins a temperature conversion
#define DS1621_STOP_CONVERT		0x22	// Адрес регистра stops temperature conversion
#define DS1621_ACCES_TH			0xA1	// Адрес регистра high temperature limit value into TH register
#define DS1621_ACCES_TL			0xA2	// Адрес регистра low temperature limit value into TH register
#define DS1621_ACCES_CONFIG		0xAC	// Адрес регистра configuration data to configuration register
// Funcion to init DS1621
void ds1621_init(void)
	i2c_init();
	i2c_start();
	i2c_send_byte(DS1621_ADR_W);
	i2c_send_byte(DS1621_ACCES_CONFIG);
	i2c_send_byte(0x01); //in LSB One Shot Mode.
	i2c_restart();
	i2c_send_byte(DS1621_START_CONVERT);
	i2c_stop();
uint8_t getTemperatura(void)
  i2c_start();
  i2c_send_byte(DS1621_READ_TEMPR);
  i2c_send_byte(DS1621_ADR_R);
  actualtemperatura = i2c_read_byte(ACK);
  temperatura = i2c_read_byte(NACK);
  i2c_restart();
  i2c_stop();
  _delay_ms(750);
I get this response:
Help me crying
BORN IN BELARUS
Try adding the i2c_restart(); line in red.
  i2c_start();
  i2c_restart();
  i2c_restart();
  i2c_stop();
  _delay_ms(750);
i2c_restart();
thank you so much!
Solved!
BORN IN BELARUS
del
BORN IN BELARUS
