I/O pullup ohm value
4 posts / 0 new
Hello freaks,
In the datasheet they talk about optional internal pull-ups of the I/O pins when configured as inputs, but I couldn't find their value. Can anyone please tell me where can I find that? I ran through the I/O section and the electrical characteristics, maybe I missed it...
thx,
axos88
axos88
In case of ATmega48 the datasheet mentions RPU=20-50K (section DC-characteristics)
/Martin.
Might depend on the chip, but if you consider the Mega48/88/168 for example, see "Typical characteristics -> Pin Pull-up"; p308-309 in my copy. OK, these graphs show pull-up current vs. input voltage, rather than a specific resistor value, but calculation of the equivalent resistance is trivial. Btw. IIRC the "pull-up resistor" isn't really a resistor, but rather a FET, which makes sense since some sort of switch would be required to turn it on/off in any case.
Well, I need 5k pullup, so I guess i will need an external pull-up anyways
EDIT: Yeah I found it under the typical characteristics, it's 25k, so I will need an external one. Thanks for your answers.
axos88
