Compilation problems (mega328p button)
9 posts / 0 new
Hello everybody! I'm new to programming on avrs. This code, despite being simple, has errors in the compilation. Need help!
Thank you very much.
   teste botão...
   MCU: Atmega328p
   Autor: ELK ALEXANDRE
   Data:  JULHO DE 2022
#include <stdbool.h>
#define F_CPU16000000UL
// --- Mapeamento de Hardware ---
#define   bt1   (1<<4)
#define   led   (1<<5)
// --- Variáveis Globais ---
int  bt1_f = 0x00;
// --- Programa Principal ---
void setup()
    DDRB  &=  ~bt1;     //configura entrada para o botão
    PORTB |=   bt1;     //habilita o pull-up interno
    DDRB  |=   led;     //configura saída para o led
        if(!(PINB&bt1)) bt1_f = 0x01;
        if((PINB&bt1) && bt1_f)
            bt1_f = 0x00;
            PORTB ^= led;
        } //end if bt1
    } //end while
} //end setup
void setup()
use ONLY = in your initialization setup, not &=  or  |=
DDRB =  flfdlfdfkdlfd
PORTB = dkgjhkdgjdjdk
Do not use bt1 and bt1_f...is is very easy to get confused and make a mistake  (Harrold, Harold) that you will not spot.
You have 200 billion names to choose from!!!  Use them
#define   bt1   (1<<4)
#define   led   (1<<5)
shouldn't these be on the SAME pin? or are your tryting to do something else.
You forget delays---your led will blink so fast, you can't see it! (are you not using an actual chip?)
Studio expects a main() function, what you have seems to be a bit of Arduino style code.
And do NOT use "Error List" to find out what is wrong anyway! It tells you almost nothing and when it does tell you anything it's in completely the wrong order.
What matters when a build fails is the "output" and within that the only thing you need to solve (initially) is the reason for the very first error you see listed there (often the fix for the first error also fixes the next 50 errors too!).
As John says the real error is almost certainly the lack of main(). Arduino sketches have two entry points called setup() and loop() but real C/C++ programs have only one called main(). In fact in Arduino it has a main() too only you don't see it. It basically says:
int main(void) {
    setup_arduino_system();
    setup(); // this calls the setup() you write in your sketch
    while (1) {
        loop(); // this repeatedly calls your loop() code
Hi! First, apologies for the delay in getting back to you.
I understand your concern about flag names etc but this is a very simple program.
Yes, I'm using the chip.
You solved my problem! It was really in main void(). Thanks a lot for the help!
Your observation of the "errors" is of paramount importance.
Thank you very much!
Ps. Sorry for the delay in getting back...
Hello,   You haven't told us if you are using standard C++ or Arduino.  With Arduino, you need to split the main() into two parts: setup() and loop().
Here is the program for Arduino:
#define   bt1   (1<<4)
#define   led   (1<<5)
int  bt1_f = 0x00;
void setup() {
    DDRB  &=  ~bt1;     //configura entrada para o botπo
    DDRB  |=   led;     //configura saφda para o led
void loop() {
   if (!(PINB & bt1)) bt1_f = 0x01;
   if ( (PINB & bt1) && bt1_f) {
       bt1_f = 0x00;
       PORTB ^= led;
   } //end if bt1
The LED will still not switch on and off smoothly because of switch bouncing. With Arduino, I suggest this loop:
    if (button press detected)  record millis() value,  add 15 to millis() value to get toggle_time,  retest millis() until it reaches toggle-time.  Then test if button is still pressed.  If yes, then toogle LED.
   Next delay until button is released, and test using millis() for 15 milliseconds in order to confirm that button is OFF.
Hi! Works fine with 20ms. Thank you for the tip.
Hug!
