Trying to use TimeB in single shot mode
7 posts / 0 new
Hi All,
I am trying to use TimerB of ATmega1608 in Single shot mode. The event to trigger this single shot mode comes from internal Analog comparator. I first initialized the Analog comparator and saw its output on pin 1 of MCU and it works as expected. Now, this output from anlaog comparator technically should trigger timerB in shingle shot mode, but its not doing right now. I am attaching my timer B snippet, please can someone tell me, is it configured correctly? If needed I can also attach my Event system configuration and Analog comparator configuration.
You need to configure the event system to route the AC output to TCB. Try this:
	EVSYS.CHANNEL0 = EVSYS_GENERATOR_AC0_OUT_gc;
	EVSYS.USERTCB1 = EVSYS_CHANNEL_CHANNEL0_gc;
One more thing, when you are writing CTRLA to enable the timer, you are overwriting the prescaler you wrote earlier.
Yes, I did that exactly, but still does not work i.e. does not give single shot output from TimerB.
For your reference
Have you configured the pulse output pin as an output so you can see it (I'm assuming you need to do so, perhaps not).  Make sure you are looking at the proper pin for this output (easy to get confused).
Also a one-time pulse is very hard to spot until your scope is properly adjusted....so at first pump out a rapid steady stream of these pulses so you can get you setup monitor ready.  Then you can do one pulse a minute.
Yes I configured PA3 pin as o/p. If technically, my single shot works for first event it receives, it should work other similar events, right?
I have tested a minimal code on ATtiny402 and it runs smoothly.
 The positive edge of the AC output triggers the TCB and a 100ms pulse will be generated.
 MCU: ATtiny402
 PA7: input (voltage from potentiometer)
 PA6: output (LED)
  _PROTECTED_WRITE(CLKCTRL.MCLKCTRLB, CLKCTRL_PDIV_16X_gc | CLKCTRL_PEN_bm);	// Main Clock 1.25 MHz
  PORTA.PIN7CTRL = 0x04;                                // disable digital input buffer
  PORTA.DIRSET = PIN6_bm;                               // PA6 as output
  VREF.CTRLA = VREF_DAC0REFSEL_1V1_gc;			// voltage reference 1.1V
  AC0.MUXCTRLA = AC_MUXPOS_PIN0_gc | AC_MUXNEG_VREF_gc; // AINP0 to IN+, 1.1V to IN-
  AC0.CTRLA = AC_HYSMODE_50mV_gc | AC_ENABLE_bm;        // select hysteresis, enable AC
  EVSYS.ASYNCCH0 = EVSYS_ASYNCCH0_AC0_OUT_gc;           // Asynchronous Channel 0, AC OUT as event generator
  EVSYS.ASYNCUSER0 = EVSYS_ASYNCUSER0_ASYNCCH0_gc;      // TCB as event user, Asynchronous Channel 0
  TCB0.CTRLA = TCB_CLKSEL_CLKDIV2_gc;                   // TCB clock source CLK_PER/DIV2 (625 kHz)
  TCB0.CCMP = 0xF424;                                   // TCB TOP value for a 100ms output pulse
  TCB0.EVCTRL = TCB_CAPTEI_bm;                          // enable Capture Event Input
  TCB0.CTRLB = TCB_CCMPEN_bm | TCB_CNTMODE_SINGLE_gc;   // enable TCB WO Output (PA6), select Single-Shot mode
  TCB0.CTRLA |= TCB_ENABLE_bm;                          // enable TCB
The truth is more important than the facts. (Frank Lloyd Wright / Unsourced)
 MCU: ATtiny402
 PA6: output (LED)
I was not ORing the CTRLA register with the enable bit and Frequency prescalar. Thank you.
