How to install avr-libc on Windows 10 for MinGW?
14 posts / 0 new
I have installed MinGW on Windows 10, and installed and verified installation of GCC, avr-gcc and make in Windows PowerShell ISE, but I couldn't find the way to install avr-libc, the bin file and source file all couldn't be operated as it was said, for example, there was not "./configure" and the "bootstrap" was just a txt file. Any suggestion?
Why on earth do you need to use MinGW in Windows simply to use avr-gcc? You can simply get the complete avr-gcc/AVR-Libc built for Windows:
https://www.microchip.com/en-us/...
Better yet you can get all that wrapped in an IDE (in fact you even get a choice of IDEs: Studio7 or MPLABX):
I haven't so much disk for studio on this machine, so I want to use CLI tools.
I tried to install Simulavr as it was said in this page - https://ccrma.stanford.edu/cours...
I ran in these steps:
$ gunzip -c simulavr-<version>.tar.gz | tar xf -
$ cd simulavr-<version>
$ mkdir obj-avr
$ cd obj-avr
$ ../configure --prefix=$PREFIX
$ make
$ make install
but, after I ran "../configure --prefix=$PREFIX", the Windows PowerShell ISE always asked me which tool I want to open this file, I don't know why.
Then, like I say you just need:
https://ww1.microchip.com/downlo...
That contains a complete installation of avr-gcc.exe and AVR-LibC. Just unzip and add the ./bin/ dierctory to PATH and you are good to go:
MianQi wrote:
... MinGW ...
... but I couldn't find the way to install avr-libc, ...
Any suggestion?
MSYS2 if AMD64
https://packages.msys2.org/search?q=avr
built from the current FSF AVR GCC (AMD64 and x86)
Releases · ZakKemble/avr-gcc-build · GitHub
old :
Using the GNU AVR toolchain on Windows 10
I read the old one, it just hasn't item for avr-libc.
AVR Libc is with the Microchip AVR GCC.
AVR 8-Bit Toolchain- Release Notes (Microchip Technology)
[page 6]
2.4 C Library
fyi, now from FSF AVR GCC 7.3 (top of page 5)
You may find this helpful: https://blog.zakkemble.net/avr-g...
I tried the 32-bit edition, it seems works.
I downloaded it, but it didn't work well.
Tell us about that - in what way did it "not work well" ?
I haven't found any file about avr-libc under this folder: C:\...\avr8-gnu-toolchain-win32_x86_64\bin
Why would avr-libc have executables in ./bin/ ?
AVR-LibC is a delivery of .h, .o and .a files. You use the .h (things lihe <avr/interrupt.h> etc) in your code and when it is built it links with the .o and .a to provide the functionality published in the .h files.
What AVR-LibC delivers is principally these two directory trees:
I found them here - C:\Program Files\avr-gcc-12.1.0-x86-windows, thanks.
