AV32 write to user page: user_page_buffer
6 posts / 0 new
I'm trying to store a value into the user page of the flash, but it's unclear to me how to write it first to the page buffer.
Using the AVR32UC3A1265
From the [Datasheet]:
Embedded Flash Start Address: 0x8000_0000
Flash Size (FLASH_PW): 256Kbytes
Number of pages (FLASH__P): 512
Page size (FLASH_W): 128 words
I came up with the code below, but I'm not sure if it's correct. Especily how to store my data (the user_page_data_t struct) in the page buffer.
There is no defined address for the pagebuffer? So how does flashc_write_user_page() know what to write?
//struct size must be == AVR32_FLASHC_PAGE_SIZE == 512
typedef struct
    uint8_t cell_address;
    uint8_t Reserved[511];
} userpage_data_t;
userpage_data_t userpageData;
//prepare data to be written
userpageData.cell_address = cell_address;
//clear page buffer (set all bits from zero to one)
flashc_clear_page_buffer();
//get the address of page buffer
uint32_t page_buffer_address = AVR32_FLASHC_USER_PAGE_ADDRESS;
// write the data to the upage buffer (Writing to the page buffer can only change page buffer bits from one to zero)
*page_buffer_address = userpageData;
//erase the userpage
flashc_erase_user_page(true);
//write from the user_page buffer to the actual user_page
flashc_write_user_page();
Can anyone elaborate on the page buffer, and how to use it to store the data you want to write to the (user) page?
does not put anything into the page buffer.
Replace the above with memcpy( (void *) AVR32_FLASHC_USER_PAGE_ADDRESS, &userpageData, sizeof( userpageData ) );
So the page buffer is the same as the AVR32_FLASHC_USER_PAGE_ADDRES?
That is not what I was expecting, since the datasheet instructs that you first have to write to the page buffer,
Then the page buffer is written to the page (user page in my case).
If AVR32 are like other AVRs then there's something like an overlaying "holding tank" superimposed on a flash page. So you start to make writes to a range of addresses in a page. But the bytes don't immediately go to the flash but a "hidden" page of RAM. When you have set up everything you want to commit you then issue a command to say "write buffer to page" (or maybe "erase page then write buffer to it") and then the whole high-voltage process of writing the N bytes of the page from buffer to actual flash occurs.
Ah oke, I think that principle is also there in the AVR32, where the "holding tank" is the page buffer.
I couldn't find any information about this buffer, but your suggestion explains that: the page buffer is already the page (but "hidden"). and the write will make that persists.
(I know it doesn't exactly work like that, but a basic understanding of the principle is enough for me, so I can use the flash functions correctly).
I will give it a try in the next few days, and I will give an update with the results.
It worked , final code to read and write to the userpage of AVR32:
Thanks for the help.
                userpageData.cell_address = 255;
                //clear page buffer
                // write the data to the user_page buffer
                flashc_erase_user_page(TRUE);
                //read the cell address from userpage
                userpage_data_t* pointer = (userpage_data_t*)AVR32_FLASHC_USER_PAGE_ADDRESS;
                userpage_data_t userpageReadData = *pointer;
                CELL_ADDRESS = userpageReadData.cell_address;
