[SOLVED] Bitshift on uint32_t problem
7 posts / 0 new
Hello
I'm using the following code to print individual bits of an uint32_t variable
uint32_t test = 0b11111111111111111111111111111111;
uint8_t size = sizeof(test) << 3; // multiply by 8
uint8_t bit = 0;
for (uint8_t i = 0; i < size; i++)
    // compute bit
    bit = (test & (1 << i)) ? 1 : 0;
    usartSend("%d - %d\n\r", i, bit);
    // do stuff with the bit
The problem is that the 16 most significant bits are printed out as 0, so the result of the above code is
0 - 1
15 - 1
16 - 0
31 - 0
The same happens if the uint32 is a random number and not just all 1's.
I verified that the variable is actually 4 bytes by printing its sizeof(), and also verified that it matches UINT32_MAX, so the variable is stored correctly in memory.
I confirmed that the code works for 8 and 16 uint variables, the problem occurs exactly after two bytes, so this must be some ignorance of mine regarding the hw architecture, what is it?
fyi, a linter generates a 'shift of signed' message.
    bit = (test & ((uint8_t)1 << i)) ? 1 : 0;
PC-lint Plus Online Demo - Gimpel Software - The Leader in Static Analysis for C and C++ with PC-lint Plus
Damn, I had read about casting the 1 to whatever type you are using earlier but had forgotten to do it, thanks!
Final code
bit = (test & ((uint32_t)1 << i)) ? 1 : 0;
This should fix it:
Also your printing the bits backwards which makes inspection difficult. I reversed the order.
uint8_t bit = 0;
for (uint8_t i = size; i--;)
    // compute bit
    bit = (test & (1UL << i)) ? 1 : 0;
BTW ltoa() with radix 2 might be a quicker/easier way to accomplish all this ;-)
(true, it does not pad leading 0's though)
Yes confirmed working, thanks.
If you don't have a barrel shifter, you can make it a bit faster:
uint8_t bit;
uint32_t mask = 1u;
for (uint8_t i = 0u; i < size; i++)
    // compute bit
    bit = (test & mask) ? 1 : 0;
    mask <<= 1;
or if the original value of test is not needed anymore:
uint8_t bit;
    // compute bit
    bit = (test & 1u) ? 1 : 0;
    test >>= 1;
