Hi all!
I am trying to setup a Project for a datalogger which uses the SDMMC-Interface of the SAMD51, 48MHz DFLL.
The mcu reads per SPI from the AFE, formats and writes to the SD-Card. The data-rate is about 25 kB/s.
With FatFS there are a lot of dropouts. So I decided to write blockwise directly to the SD. This is working so far. Anyway, I get every 2,5s 60 or 100 ms gaps in the data writen. Beside one pinchange-controlled interrupt all other activities seeme to be blocked during the writing activity. I tryied to optimize it with using 2 buffers 128 blocks each alternating.
Now I saw, that the START-derived code works with a by word writing and I assume, that everything is diabled duringthe writing.
My question is, how it is possible to use a DMA-mode of the SDMMC-Interface to make other activities possible again during the writing.
Does anyone have experience how to modify this?
Thanks !!!!
Jun
