Hi
I have a complicated situation in that I need to control the opening and closing an actuator from a relay
The actuator has a stepper motor that has 24V supply and needs 0-10 V command
I have only on off relays, and the logic needs to be as follows: when i give voltage from the relay , the actuator should open or close and when I take the voltage , the actuator should close or open
I need to know if there exists such equipment and where I can find it
