USB development tool
13 posts / 0 new
Total votes: 3
I have no affiliation to this so this is not an endorsement nor an advert but from time to time we've had threads here about USB development and in particular how to do USB protocol analysis. So this just dropped into my email Inbox:
https://coolcomponents.co.uk/pro...
That seems like a good price compared to a lot of more "commercial" gadgets that offer the same kind of functionality (I've hired equipment in the past but I think it was about £500/week!)
Only downside is that lead time - so maybe for "next year's project" ?
Perfect, must get one.  Thanks clawson....
awneil wrote:
gives some US suppliers also taking pre-orders
Thanks (Mouser through Crowd Supply)
Great Scott Gadgets Other Modules – Mouser (ETA 14-Jun'22)
Mouser look to be expecting it to be popular, with quite high order numbers.
Does sound a nice piece of kit, if you have USB low levels problems.
It's not clear if the digital IO can capture general IO to 480MSps speeds, allowing the unit to be used for eg UART jitter measurement ?
Back in the old days, UARTS had crystals, and simply binary dividers, meaning you got quite predictable and precise signals from them.
These days, even Crystal based mid range MCUs can add spread spectrum to their PLLs, and fractional Baud designs can jitter across many bytes.
All that makes extracting timing info from UARTS harder than it used to be...
 UARTS was the protocols.
www.tokopedia.com/madagang .Buy and Donated cheap electronics and manuscripts.
especially for high-speed USB.
Was unsuccessful in locating clock information in the documentation (short search)
KiCad can be converted to web doc.
Some USB UART have a clock output that's dependent on USB SOF (is USB SOF accurate enough?)
up to full-speed USB :
https://github.com/greatscottgadgets/luna/tree/main/hardware/rev0
CADLAB.io | Visual collaboration and version control platform for your PCB
USB in a NutShell - Chapter 2 - Hardware | Data Signaling Rate
I found the FPGA uses a 60MHz sysclk, which also feeds into the USB USB3343 PHY's, so it seems to do no low level checks at 480MHz, it relies on the USB3343 'simply working'.
I did see a note saying they had to upgrade the 60MHz oscillator to one with less jitter, to improve HS-USB operation.
They usually lock a DPLL to the USB SOF, and the step size on the low cost ones is not great, usually 0.1~0.3% ballparks.
HS-USB parts are better, as they all need to use XTALS.
LUNA - LUNA delayed | Crowd Supply
Nov 10, 2021
Unfortunately, LUNA is now expected to start shipping December 2022 because the lead time for the ECP5 FPGA chip we use on LUNA doubled between July and September. There isn’t a suitable substitute component for the ECP5, so our timeline depends on Lattice’s production schedule for this chip.
The delay gives our small team even more time to hone the LUNA software and experience before getting it into your hands. We will use this time to collect and address more feedback from our beta testers, create extra demos and training material, and continually improve our documentation.
About the Author
Straithe
straithe
This is the post I was looking for. I'll buy one when it comes out.
Looks unknown to me. Is it Xillinx compatible?
No
ECP5 / ECP5-5G (Lattice Semiconductor)
