Hi Everyone,
I have an ATSAM4S2A and I want to use the SPI interface in master mode, as well as the SSC in I2S to interface to an audio codec. The SSC works well until I put the SPI in Master mode. The SPI seems to work until I enable an interrupt for the SSC. I cannot get both peripherals to work at the same time.
Any help will be very much appreciated!
My init for the SSC:
void Init_SSC(void) { NVIC_SetPriority(SSC_IRQn,2); NVIC_EnableIRQ(SSC_IRQn); REG_SSC_CR = SSC_CR_RXEN|SSC_CR_TXEN; REG_SSC_CMR = 0; // Transmit: DataLength= 16, MSB first, 1 Words/Frame, FSLEN=32 REG_SSC_TFMR = ((16-1)<<0)|(1<<7)|((1-1)<<8)|(1<<23)|(0xF<<16)|(1<<28); // Transmit: SCLK from TK, Start on any edge of TF, 1 SCLK delay REG_SSC_TCMR = (2<<0)|(7<<8)|(1<<16); // Receive: DataLength=16, MSB first, 1 Words/Frame, FSLEN= 32 REG_SSC_RFMR = ((16-1)<<0)|(1<<7)|((1-1)<<8)|(0xF<<16)|(1<<28); // Receive: SCLK from TK, Sample on RisingEdge, Start on TX Start, 1 SCLK delay REG_SSC_RCMR = (1<<0)|(1<<5)|(1<<8)|(1<<16); REG_SSC_IER = SSC_IER_TXRDY|SSC_IER_RXRDY; }
And for the SPI:
void Init_SPI(void) { NVIC_SetPriority(SPI_IRQn,1); NVIC_EnableIRQ(SPI_IRQn); REG_SPI_CR = SPI_CR_SWRST; // Reset SPI REG_SPI_MR = SPI_MR_MSTR|SPI_MR_PCS(0)|SPI_MR_MODFDIS; // Set MasterMode REG_SPI_CSR = SPI_CSR_BITS_8_BIT | SPI_CSR_SCBR(20); // Set BitRate at Fper/20 REG_SPI_IER = SPI_IER_TDRE; // Enable TDRE Interrupt REG_SPI_CR = SPI_CR_SPIEN; // Enable SPI }
