Port Bits als Makro / Port Bits as macro
3 posts / 0 new
Hallo Leute,
ich möchte einzelne Port-Bits mit Hilfe als Verknüpfung setzen oder auslesen.
Mit Bascom-AVR kann ich mit Alias verknüpfen, aber C/C++ habe ich noch nicht raus gefunden.
---------------- ENGLISH ---------------------------
Hi guys,
I want to set or read individual port bits with help as a link.
With Bascom-AVR I can link with alias, but C/C++ I haven't found out yet.
BASCOM-AVR Example:
LED1 Alias PORTA.7
LED2 Alias PORTA.6
Taster1 Alias PINB.0
Taster2 Alias PINB.1
Taster3 Alias PINB.2
Main:
   do
      if Taste1 = 0 then
         LED1 = 1
      elseif Taste2 = 0 then
         LED2 = 1
      elseif Taste3 = 0 then
         LED1 = 0
         LED2 = 0
      end if
   loop
end
Wie muss ich das machen das ich in C/C++ einzelne Ports und Pins verknüpfe.
--------------------- ENGLISH ----------------------------
How do I have to link individual ports and pins in C/C++.
C/C++
#define LED1 (Link to PORTA.7)
#define LED2 (Link to PORTA.6)
#define Taster1 (Link to PINB.0)
#define Taster2 (Link to PINB.1)
#define Taster3 (Link to PINB.2)
void main(void)
        if(Taster1 == 0)
            LED1 = 1;
        else if(Taster2 == 0)
            LED2 = 1;
        else if(Taster3 == 0)
            LED1 = 0;
            LED2 = 0;
Grüße / Greetings
Patrick Dreger
Microchip do support this access method, but only for PIC devices where much like 8051 you could say it is a de-facto standard.
The header files required to make this work are absolutely huge as a result and indeed you could copy the method used on PIC devices onto AVR but it would be a really big job of work. If you did this just for PORTx registers it would be manageable though.
I did this PORTS only work myself on one project but discovered that it was a lot of work for essentially little gain. I now universally use hardware abstraction macros thus:
// LED OUTPUTS
#define GREENLED_ON()  PORTB &= ~(1<<1)
#define GREENLED_OFF() PORTB |=  (1<<1)
// KEY INPUTS
#define IS_KEYPRESSED() (!(PINE & (1<<3)))
Edit:
Here's an old thread on the subject. Try to avoid the "tabs vs spaces" noise.
https://www.avrfreaks.net/forum/register-definition-mcu-header-file-pic-vs-avr
It would be pretty easy in C++
nearly impossible in plain C, I think, but “setio (Led1, 1)” would be ok.
