KAVRCalc Discussion Thread
74 posts / 0 new
I've uploaded a new version of KAVRCalc to http://b9.com/elect/avr/kavrcalc/ . I believe I added everyones' requests, except for the request of generating code.
Some people have had difficulty starting the program on their systems, I presume secondary to some missing DLL. I also uploaded a debug version for those people who encounter trouble. If one has trouble starting the program on their system, please download and test the debug version and post a follow-up.
Bug reports and feature requests are welcome. When, I'm done with the calculator portion, I'll be adding an AVR part browser in anticipation of eventually adding a code generator.
Also, I'm considering purchasing the Mac OS X version of the development software so I can publish a Mac version. If anyone is interested in a Mac version, please let me know so I can gauge interest on that platform.
Edit: Change subject title
I don't quite understand the need for baud rate calculation, but hey, if it makes someone happy... :)
Well, John, that was my thought, too. I didn't need it, but someone ask for it and it wasn't too hard to add.
Looks great... I can only find 2 things I might need soon.. I want to push a 20mhz avr and the next magic freq is 11.059 x 2, so that would be a good entry in the clock table, and 230 and 460kbps rates for talking to xports.
Sure, Bob, I'll add those to the next release. Also, keep in mind that you can enter any arbitrary frequency or baud rate into the input areas.
SteveN wrote:
Just wondering out loud, would it be worthwhile to have a warning about new AVR's running on internal RC oscillator at 1MHz? Of course this warning would not apply to older (very old) AVR models.
So, Steve, you're talking about the CLKDIV8 fuse? I'm not quite sure how the warning is apt as I include a few clock frequencies above where all AVR's can currently specified to operate, like Bob's 22.1184MHz frequency. Perhaps your suggestion would be more appropriate for a fuse calculator (or my upcoming AVR parts browser).
Can you explain more about where you think the warning would be appropriate in the calculator display? Or, are you thinking of having a FAQ popup window (like the About popup) with some common important statements.
The result text is pretty hard to read on my system. The previous version had black text in a white box, but now it's kinda beige-ish text against the background color. I think we lost something in the translation. :)
Stu
Yes, Stu, I'm aware of the change in color. I'm sorry to hear thtat it is hard to read on your system. I made the change so the background color of the computations will match the background color of the application. The only way I found so far was to make the computations "disabled" which changed the foreground color to a different shade of gray. I'll see if I can improve the appearance in future releases.
SteveN wrote:
I was thinking of a note in parenthesis somewhere in your "CLOCK" section. Something like: "(Note: check device fuse settings for frequencies other than 1MHz)".
Thanks for the additional explanation, Steve. Your idea has merit. I'll look to incorporate your suggestion in a future release.
I uploaded version 1.6 with a fix to a title, improved About window, and Bob's clock and baud requests.
Linux version now available again.
The background colors now all match up but as someone else pointed out the text is a too light a gray to be readable. Why not simply change the text foreground color to black to match the text labels?
I asked for the numbers in two clock speed fields to be the same (one had 1 and the other had 1.0). Now all the numbers in one field have 6 decimal places and the other has 5 decimal places. This is still not consistent and I think less readable now. Each field should use the same list of numbers such as 1.0, 1.8432, 2.0, 2.4576 etc.
I still like my tabbed panes idea but if you don't, you could clean up the layout a little by moving the Watchdog area to be in the top right above the Timer Calculator.
--Mike
Because when I change the foreground text color, the background text color change so it does not match. I've not yet found a work-around for this.
The clock speeds should all have 6 decimal places now and they do on my review. What clock speeds do you see that have 5 decimal places? Are you referring to a different field in the "Acceptable Common Clocks?"
I thought what you didn't like was that different clock speeds had different number of decimal places. I can make the "Acceptable Common Clocks" have 6 decimal places so everything is consistent.
I live tabbed panes quite fine. As previously mentioned, I have plans to use tabbed panes, but to add them for non-noncalculator functions. Yes, I did consider moving the watchdog calculator to that corner, I think it is a good idea.
Thanks for your suggestions.
Thanks for adding the hex to string to binary feature!
WoW. I've never seen a Software Change Request impemented and released with overnight turnaround. Never. Ever. If you were in the programmer's union, the shop boss would send Tiny over with the baseball bat to slow you down a little.
Yes exactly. I have been referring to the two fields, not the values in the fields. The acceptable clocks field has 5 decimal places.
So I'm suggesting you go back to what you had and just make the same value have the same number of decimal places. The number of decimal places may vary by value (e.g. 1.0 and 1.8432) but it is consistent, and familiar to everyone. The value 1.843200 is a little harder to read than 1.8432.
I think you have written a good application and it can be very useful. Great job !!
--Mike
:) Very funny, Bob! To be fair, your change required less than 1 minute of editing, so I can't take much credit except being responsive to your good suggestion.
Edit: Why is it that people named Tiny are usually not as small as their name replies. I thought of that one day while a posting from Smiley where he mentioned he almost cracked his face getting a bit of smile on camera.
Thanks for the additional information, Mike. It'd be simple to add a filter to remove trailing zeros and use the same filter for both fields.
But, I do wonder about your original suggestion. Didn't your suggestion come prior to the "Acceptable Common Clocks" subsection? In any case, I was focused only one the Clock selection section -- but having those two fields be the same is a good idea. The only significant disadvantage of differing number of decimal points in "Acceptable Common Clocks" is that the error percentage will no longer line up which also has a decreased readability issue. But, perhaps people would have that number not be aligned rather than trailing decimal zeros.
You're very welcome, David. I hope it comes in handy for you -- thanks for the suggestion.
Kevin,
My issue has been resolved by bringing home the unzipped .exe (using PowerArchiver, I think) and it works fine on my XP machine. It now appears that unzipping it with WinRAR was the problem.
Nice job.
Dave
Kevin,
It's really a great piece of software. The only problem I have had is that I couldn't resize the window. I am using linux (by the way, the executive file seems to be a bit bulky, especially, that you depend on an external library). My screen is just 1024 x 768 big (or small), so the bottom of the calculator disappears under my task bar. Can you fix that? I would be very sorry, if I couldn't use it just because of this small glitch.
Cheers,
Zoltan
Davef, that's interesting. Are you are testing the .exe (unzipped by two different unzippers) on two different machines? Or, was it your home XP machine that it previously did not work on and now does? If the latter is true, would you be able to compare the 2 .exe files for number of bytes and md5sum? If this is truly an unzip issue, then maybe I have an isse with my zip file creation program. Thanks for the report.
Thanks for the linux report, Zoltan. Yes, it is a bit bulky, mostly from bundling Motif libraries into a static executable as well as including debugging information (to assist in the previous reports of people having trouble with the linux version)
As for the size, the next version (at this point) will have a shorter window because of moving the watchdog section as Michael recommended. But, I noticed the motif (linux) version is a larger window than the microsoft windows version. The motif version has taller lines of text and extra spacing between text lines compared to the windows version.
There is the 18.42 MHz magic frequency...and that would keep you within specs...you old reckless speed freak teenager... :lol:
Staying within specs, John? Heh, what adventure is there in that!
I uploaded version 1.7. No new features, but layout and number formatting as suggested by Michael. Michael, did I get the formatting as you'd like?
Nitpick time: When reentering a number into the "desired timing" text box, I accidentaly put ".0000" there. The program crashed. The same thing happened when I entered "0". Everywhere else when I enter zero, the program is OK.
Version 1.6
[/nitpicking]
I think you and I have a bit different concept of nitpicking, David. An application crash due to user input, no matter how innocently or devilishly constructed, is a bug of great importance. I thought I got all the division by zero errors caught, but I missed that one. Thanks very much for the report. Do try to break the program in whatever way you can, such exercises help exorcise the bugs. Again, thanks for the report.
OK, so another one:
When I enter a <0 (minus) value into the Decimal text box it gives out a bit of gibberish on the hex outputs.
For instance, a number -123456 gives these hex results:
Hex Integer: 00 -1 E2 40
IEEE 32-bit: -3 80 EE 00 0
Your program helped me today, as I needed to set the timer up for 8ms intervals! Thanks!
I tried 1.7. The number formatting is now like what I suggested and I think you agree it looks better. The watchdog panel fits nicely in its new slot (until you add a tabbed pane).
However there are a few remaining nits that I would like to point out:
  1. The acceptable common clocks does not have a frequency of 1 MHz whereas the Clock does.
  2. It seems like for whatever reason you are calculating the acceptable common clocks frequency because there is a rounding error with 18.431999. The usual way to do this is have two arrays (one with the actual numbers and one with the text values)
  3. Are people really using non-divisible clock speeds like 3.579545 MHz with AVRs? I'm surprised to see these values and I would remove them
  4. Something weird is happening to the clock frequency field which I think is leftover code. After clicking on the acceptable common clocks list, the clock frequency field at the top left changes to show the number in that field with 6 significant digits i.e. 8 is redrawn as 8.000000.
  5. The text color in the acceptable common clocks is blue which is not used anywhere else. You might want to change it to match the other output text color (currently light gray). Or you could change the output text color to blue I guess.
--Mike
Cool report, I haven't tested it with negative values after I added to byte separation spaces. I'll check it out and fix it up.
Neat, glad to hear that you have found the application useful!
Thanks for the feedback and the clock formatting. I agree with your other points and appreciate the suggestions while I work on the next version.
The list of clock frequencies is the same for two fields. I see 1 MHz when I increase the maximum baud error (increase to 99% to see all clocks).
I don't know if people are using that crystal with AVR's, but since it's a common crystal like 4.433618MHz (color burst frequencies for NTSC and PAL), I thought I'd include them.
But, I'm glad to remove them. Since people can enter an arbitrary frequency, there's no need to have selectable anything but common frequencies. Along that same thinking, it'd make some sense to remove frequencies above 20MHz since they are not used with AVR's (excepting for that overclocking 22.1184 request).
Edit: At this time, I have the below list of frequencies to keep and remove. Anyone who has an opinion of what frequencies they'd like, let me know.
Keep: "0.032768" "1.0" "1.8432" "2.0" "3.2768" "4.0"
  "7.3728" "8.0" "9.216" "10.0" "11.0592" "12.0"
  "14.7456" "16.0" "18.432" "20.0" "22.1184"
Remove: "2.4576" "3.579545" "3.6864" "4.433618"
  "4.608" "4.9152" "5.0688" "6.0" "6.144"
  "14.31818" "32.768" "40"
Hey kmr,
I was wondering what programming package are you using to built your kavrcalc software?
Shane
Hi Shane, I'm using my favorite programming language, ANSI Common Lisp. While there are free, open-source versions of Lisp available (some with graphical user interface tools), I'm using the commercial LispWorks ( http://www.lispworks.com ), because if offers graphical user interface that is compatable across Windows, Linux, and OS X.
I've uploaded version 1.8 to http://www.b9.com/elect/avr/kavr...
From the ChangeLog:
Version 1.8 (Jan 19, 2008)
	- Fix error when "Request Timing" is 0
	- Don't display OCRA/OCRB frequencies when input is blank
	- Remove uncommon clock frequencies
	- Fix error in 32-bit Number Calculator when entering negative decimal
	- Improve number formatting in Acceptable Common Clocks
	- Change visual display of computed values for greater readability
I can't run it under Ubuntu 7.04, complains about the lack of libXm.so.2. Do I need the Motif (probably Lesstif would work). It does work under Fedora 6 which I think I loaded Lesstif. On Fedora I note the same problem as Zoltan (can't resize, can't access the bottom as it off my window 1024x768).
Neil Cherry
Linux Home Automation
Author: Linux Smart Homes For Dummies.
I can hardly keep up ..... HELP !
I don't know how it is for other users, but these old eyes have difficulty reading the grey results ... and I notice that you fixed that already. :)
But the kavrcalc.zip version 1.8 is having an unexpected end ...
Nard
Edit: with WinZIP and WinXP-built-in unzipper
Yes, Lesstif would work fine. I built the image with Etch 32-bit, so Ubuntu 7.04 32-bit Intel should work. For 64-bit Linux, you'll need to grab a 32-bit version of the Motif/Lesstif library. Yes, there is no resizing on the main frame and the Motif version has a larger frame than the Windows version. I'm far from an expert on Motif. Do you know if you can set some X-Window font parameters to reduce the size of the fonts to perhaps shrink the frame so it fits on your screen?
While I can't shrink the frame without removing some components (or going to a tabbed pane approach), I could reorganize the frame to be wider and shorter to fit into shorter displays.
Sigh, such is the disadvantage of high-level programming languages allowing significant, rapid changes in functionality. One reference: Beating the Averages: http://www.paulgraham.com/avg.html
It looks like there was a corruption of the zip file on upload. I reuploaded and verified the md5sum's. Sorry about that. Would you mind retrying?
:lol:
I will go for the retry NOW
Nard
Edit: works as a charme. And thanks for the better contrast !
Thanks very much for the report, Nard!
Hi Kevin,
Great application - really like the inclusion of the ASCII calculator... thanks :D
Only thing I would like to see changed (and it is a really small nitpick !) would be to have the app appear centred in the desktop by default. Currently it appears towards the left and top @ 1920 x 1200.
I know, I know - but my old boss was a stickler for this sort of thing and I guess it sunk in :wink:
{Edit} This is on the XP version btw.
Cheers
Robin
When I unzipped the program on a XP machine using WinRar it didn't work. When I unzipped the program on a Windows2000 machine using PowerArchiver it worked. Then I put the .exe that was unzipped by the Windows2000 machine on to the XP machine and it worked.
BTW, 3.6864MHz is the frequency I use all the time. I thought it was pretty common.
How do I check md5sum?
Dave
Dave, there's a program here that will do it :
http://www.md5summer.org/
I found that the latest version of Winzip unzipped everything OK.
HTH
Robin
Cool, I'm glad that you like the program. The ASCII calculator was David's idea, so he should get thanks as well.
That's an interesting thought. I hadn't heard of that guideline/rule for placing applcations on a desktop. Do you have a reference for that suggestion? I tested a handful of applications on my Vista system and none of them open in the center of the screen. That said, I'd be glad to do it, I just wonder if you can provide some reading material about suggested locations of applications on the desktop.
Thanks again for your comments.
Thanks for the information, Dave. You're right, 3.68664MHz is a useful UART clock rate. I'll put 3.6864MHz back in the default clock list.
Hi Kevin,
Originally I didn't have any references, it just "feels right" to centre the window, but I found this - here's the gospel according to Microsoft:
http://msdn2.microsoft.com/en-us/library/aa511262.aspx
There's reference to "Top Level Utilities", I guess that would cover your app.
Cheers
Robin
PS - Re the discussion about available selections for crystal frequencies, you could have an external text file (or XML perhaps) which the user could specify 'odd' frequencies, to be read and added to the drop down list at startup ? I guess this would break the single executable aspect though.
Thanks for the reference, Robin. I've already add code so the application starts in the center of the desktop. Since people can enter their own arbitrary frequency, I probably will put the idea of user-modified frequency list on hold. One slight workaround is to save one's current clock frequency and then load that file when you want to use that clock frequency. Yes, to store user data, one would need a default home location to the application.
Not really. Just use the location of the application.exe itself. That is what I do with most of my applications because you cannot guarantee that the user will follow your location recommendations.
Cheers,
Thanks for the input, Ross. Yes, I've used that approach as well. The main disadvantage (or possible advantage for sophisticated users) is the possibility of having multiple copies of the application thus multiple data files with the user getting confused why the application seems to have different data each time. But, having a typical location for user data is supported by all common operating systems.
Kevin,
With respect, you are trying too hard. Users need, at some stage, to act as adults and be responsible for THEIR actions. If they install multiple copies ... so be it. But as a small concession to those not quite up to par, I guess you could add the folder location to the title bar of the currently running instance. Hopefully they can read! :lol:
Nice work btw.
Cheers,
Thanks, Ross. In my many years of supporting users, it's been my experience they (at least the ones who ask for help) try as little as possible to be responsible for their actions. ("Hey, this program should tie my shoes as well" :)) Nonetheless, your point is very well taken, thanks.
Yes that was it. With the large errors that 1 MHz has over 4800 baud, perhaps Atmel should be shipping AVRs with an internal clock of 0.9216 MHz or some other magic frequency.
I downloaded the 1.8 version. I would fix up the numbering in your BSD-style license. Is the source code going to be available?
The text output fields on my Windows XP now appear as blue text on a light blue background with a line around them. Which platform is your screenshot from because mime looks totally different?
--Mike
Thanks for the numbering tip. I'm not planning on publishing the source code, I doubt there is a single member on AVRFreaks who has spent the $1500 for the development platform for which the source code is targetted.
I don't change the background from default, so I think the background will depend upon your theme. I'm using Vista Ultimate with graphite coloring (since I do a lot of digital photography so I want as few extraneous colors as necessary).
I changed my scheme and yes the background color changed. However I cannot be the only one here who is using Windows XP with the standard scheme. The problem is probably the worst for people who are color blind. I'm guessing the red on blue looks like all the same shade of gray and therefore very hard to read. You might want to temporarily change your scheme back to the default to see how it looks on Vista as well.
On suggestion is to set the background color for each control to white. And black text is probably better than blue if you can make it consistent everywhere. I suggested previously that a different type of control such as static text might be better than what I think you are using which is a read-only entry field.
--Mike
Kevin,
Problem seems to have gone away with version 1.8
And thanks Robin for the link to md5summer
Cheers,
DaveF
Sound like to accomodate users with various themes that I should either not change the foreground, or if I do change the foreground, to also change the background.
The fields that are read-only are a static text in the cross-platform GUI framework that I'm using. However, these static fields are rendered similiarly to text input fields and I'm looking for some reasonable, cross-platform, cross-theme differentiation for read-only and input fields. So far, I don't think I've been successful because each variation I implemented has cause trouble for somebody despite being perfectly readable for me.
But, I'll keep working on the issue.
Thanks for the report, Dave!
Tested 1.8 normal an debug version on Windows 2000 Sp4. Both version don't work, because MSVCR80.DLL is missing. MSVCR80.DLL is the C runtime library version 8.0 redistributable.
Tried 1.9 both normal and debug version on Windows 2000 SP4. Both versions don't work, because of the famous "missing msvcr80.dll" error message.
Thanks for the reports, StefB. Here's a link to download an installer for MSVCR80.DLL: http://www.microsoft.com/downloa...
Looks like I'll need to create an installer package that will install the DLL, or just put the above link in a README file.
Thanks. That helped.
Ah now I was going to suggest that you publish (and if so use FreeBSD not GPL) but later I read it was Lisp. My original idea being that the "team" could collaboratively add the "things they want" themselves - but I doubt that would happen anyway in Lisp! ;)
Cliff
Actually, Cliff, several components that I use in KAVRCalc have been published as open-source packages. A list of my open-source repositories is at http://gitpub.b9.com/cgi-bin/git...
Currently, I'm using cluck (a microcontroller clock library) and kmrcl (set of lisp utilities) in kavrcalc. But, I've never received any feedback, suggestions, or patches for cluck. I just don't think many freaks here use Lisp. And, kavrcalc is more specialized requiring a commercial development system for its GUI component.
On this page:
http://en.wikipedia.org/wiki/Lis...
I particularly enjoyed the comment from Larry Wall (Mr. Perl)
Cliff
Thanks Kevin,
Excellent utility. I was fiddling with its features. Stumbled upon some thing which you might want to know.
Ever tried making some changes, saving the data to a text file and re-loading it ?
I get a message box which spans about 17 inches (goes out of my 15" screen) and says "Invalid file format" followed by the entire content of the file in one line.
I am running it on Win XP Media Center Edition.
Yes, but not in the latest versions.
The content of the file being displayed is from old debugging work. I'll fix that in the next release as well as figure out what broken since the last time I tested saving then loading the calculator state. Thanks for the report!
Larry's always been of strong wit. I like his more recent quote on Lisp on this page: http://www.perl.com/lpt/a/997
Paul Graham's 1983 quote on the Wikipedia link you provided interestingly compares with later use of Lisp as his "secret weapon" in his commercial success: http://www.paulgraham.com/avg.html
I found at least some older versions of KAVRCalc produced an invalid save file. With a prerelease 1.9 version, I'm getting valid save and loads.
Can you try saving from version 1.8 and see if you still have a problem? If you do, is it possible for you to PM the file to me so I can debug it?
Thanks!
Kevin
Kevin,
I was testing v1.8.
I have already sent a PM to you with the contents of the file.
Kevin,
Thank You VERY much for this GREAT tool.
As a beginner with AVR's and being new to programming, EVERY little tool helps. Your application makes checking Freq/Baud rates and Error % so much easier. No doubt I will be utilizing the rest of your Tool in the near future.
Thanks again for your time and effort.
Regards
puzzledbee wrote:
I was testing v1.8.
Thanks, PB!
Thanks for the kind words, Ozra -- glad to hear the time I've invested is of benefit to others.
