Hi all,
I am trying to toggle an LED in ~1sec intervals. ATtiny3217 is running at 8MHz. TCA0 runs in normal mode and uses a prescaler of 256 -> Period is set to 31250=8000000/256.
#define USART0_BAUD_RATE(BAUD_RATE) ( (float) (8000000 * 64 / (16 * (float) BAUD_RATE)) + 0.5) void setup() { CPU_SREG = 0 << CPU_I_bp; /* Disable interrupts */ /* * INITIALIZE SYSTEM CLOCK * */ _PROTECTED_WRITE(CLKCTRL.MCLKCTRLB, CLKCTRL_PDIV_2X_gc | CLKCTRL_PEN_bm); while ( CLKCTRL_MCLKSTATUS & CLKCTRL_SOSC_bm ) {} /* Wait for system oscillator change to finish */ /* * INITIALIZE TIMER/COUNTER TYPE A 0 * */ TCA0.SINGLE.CTRLB = TCA_SINGLE_WGMODE_NORMAL_gc; /* Waveform Generation Mode: Normal */ TCA0.SINGLE.CTRLESET = TCA_SINGLE_DIR_UP_gc; /* Counter Direction: incrementing */ TCA0.SINGLE.EVCTRL = 0 << TCA_SINGLE_CNTEI_bp; /* Enable Count on Event Input: disabled */ TCA0.SINGLE.INTCTRL = 1 << TCA_SINGLE_OVF_bp; /* Timer Overflow/Underflow Interrupt enable: enabled */ TCA0.SINGLE.PER = 31250; /* Set period */ TCA0.SINGLE.CTRLA = TCA_SINGLE_CLKSEL_DIV256_gc /* Clock Select: f_CLK_PER/256 */ | 1 << TCA_SINGLE_ENABLE_bp; /* Enable: enable */ /* * INTIALIZE I/O * */ PORTC.DIRSET = 1 << PIN3_bp; /* Data Direction Set: output */ PORTC.OUTCLR = 1 << PIN3_bp; /* Output Toggle */ CPU_SREG = 1 << CPU_I_bp; /* Enable interrupts */ } ISR(TCA0_OVF_vect) { PORTC.OUTTGL = 1 << PIN3_bp; /* Output Toggle */ TCA0.SINGLE.INTFLAGS = 1 << TCA_SINGLE_OVF_bp; /* Clear overflow interrupt flag */ } void loop() { }
Problem: LED doesn't toggle on the second, but shines continuously instead. (toggling frequency too high to be perceptible with human eye? but why?)
