Analog Comparator no response
7 posts / 0 new
I try to use Analog Comparator on ATTiny461A. The voltage of the AIN1 changes according to below table.
                       I/P         Normal       Left        Right
AIN0 (Pin 12)  NEG          2.5v         2.5V       2.5V
AIN1 (Pin 11)  POS           2.5V        2.1V       2.6V
AC0                                                  0           1
I wish to compare AIN1 to AIN0. If AIN1 voltage more than AIN0, AC0 to be set.
I try to get below code work, but there isnt any response on the output pin. i attached the datasheet table.
void port_init()
	DDRA |= (1<<PINA6) | (1<<PINA7); //AIN0 AND AIN1 AS INPUT
	DDRB |= (1<<PINB4)| (1<<PINB6);//OUTPUT PINS
void AC_Init(){
	ACSRA = 0b00000000;
	ACSRB = 0b00000010; //ain0 as negative input, ain1 as positive
	port_init();
	AC_Init();
	while (1)
		if ((ACSRA & 0X20) == 1)
			PORTB |= (1 << PINB6);  //PINB6 HIGH
			PORTB &= ~(1 << PINB4);  //PINB4 LOW
			PORTB &= ~(1 << PINB6);  //PINB6 LOW
			PORTB |=  (1 << PINB4);  //PINB4 HIGH
Is there anything else I need to set on the ACSRA, ACSRB register or ADCSRA register ?
I have try set ADEN to zero, it doesnt work too.  Any help is much appreciated.
Go on.
can NEVER happen.
If you want to test (ACSRA & 0x20) you
either say      if ((ACSRA & 0x20) == 0x20)
or use this     if ((ACSRA & 0x20) != 0)
Personally I just say     if (ACSRA & 0x20)
because I am an old 6502 programmer.   But modern C compilers give a warning.
No I have not studied your actual code.   The Analog Comparator is pretty simple.   Just read the datasheet.
Oh,  and use proper bit-masks instead of a magic 0x20
You should use ACI and/or ACIE.
you mean have to use ISR and the test of the ACO bit have to be located inside the ISR vector ? i will try all and updates.
You never need to use an ISR().
Set AIN0, AIN1 as inputs.   Enable ACME / ADEN and monitor the ACI flag.   Read the ACO output bit.
But you could ignore ACI and just act on ACO bit.
It should be pretty straightforward.
Bits ACI, ACO and Interrupt are described in AVR128.
OK. I got it working. Thank you very much all.
