I was hoping you could please help me with this issue.
Im using a SAMD21 with ASF4 as a virtual USB host to send and receive data. I can successfully send and receive but its every other attempt. For example:
1) Send data, read back expected result
2) Second attempt to send data "cdchf_acm_is_writing" is true so it doesnt send request or read response.
I used "cdchf_acm_write_flush(p_cdc);" however "cdchf_acm_is_writing" was still true. Can anyone help explain why this would be?
This is the implementation I used.
#include "hst/usbDevice.h" static const uint8_t PORT_OPEN_SUCCESSFULLY= 3U; static struct cdchf_acm *p_cdc_inst = &USB_HOST_CDC_ACM_0_inst; bool USBinit(void) { usb_init(); usbhc_start(&USB_HOST_CORE_INSTANCE_inst); bool b_connected = USBwaitConnection(); if(b_connected){ const uint8_t u8_status = port_open(); if(u8_status == PORT_OPEN_SUCCESSFULLY){ b_connected = true; } } return b_connected; } static bool USBwaitConnection(void) { bool myDevicePresent = false; uint8_t u8_attempts = 0; while(myDevicePresent == false && u8_attempts < 5) { if (IsConnected()) { if(p_cdc_inst != (struct cdchf_acm *)NULL) { cdchf_acm_register_callback(p_cdc_inst, CDCHF_ACM_READ_CB, (FUNC_PTR)port_read_complete); cdchf_acm_register_callback(p_cdc_inst, CDCHF_ACM_WRITE_CB, (FUNC_PTR)port_write_complete); myDevicePresent = true; } } delay_ms(300); u8_attempts++; } return myDevicePresent; } static void port_read_complete(struct cdchf_acm *p_cdc, uint32_t u32_count) { } static void port_write_complete(struct cdchf_acm *p_cdc, uint32_t u32_count) { cdchf_acm_write_flush(p_cdc); } static uint8_t port_open(void) { const uint8_t ERROR_WAIT= 4U; const uint8_t WAIT_CONN= 0U; uint8_t u8_ret = 0U; static usb_cdc_line_coding_t lncoding = {115200, CDC_STOP_BITS_1, CDC_PAR_NONE, 8}; if (! IsConnected()) { //Port 0 not found u8_ret = ERROR_WAIT; } else { if (ERR_NONE != cdchf_acm_open(p_cdc_inst, NULL)){//&lncoding)){ //Failed to open port 0 u8_ret = ERROR_WAIT; } else { while (u8_ret == 0U){ if (cdchf_acm_is_error(p_cdc_inst)){ //Error while opening port 0 u8_ret = ERROR_WAIT; } if (!IsConnected()){ //Detach while opening port 0 u8_ret = WAIT_CONN; } if (cdchf_acm_is_open(p_cdc_inst)){ //Port 0 opened u8_ret = PORT_OPEN_SUCCESSFULLY; } } } } return u8_ret; } bool IsConnected(void) { bool b_connected = false; if(p_cdc_inst != (struct cdchf_acm *)NULL){ b_connected = cdchf_acm_is_enabled(p_cdc_inst); } return b_connected; } bool send(uint8_t *pu8_txData) { bool b_status = false; if(p_cdc_inst!=(struct cdchf_acm *)NULL){ int32_t i32_code = 1; if (! cdchf_acm_is_writing(p_cdc_inst)) { i32_code = cdchf_acm_write(p_cdc_inst, pu8_txData, USB_PACKET_SIZE); } if(i32_code == 0){ b_status = true; } } return b_status; } bool receive(uint8_t *pu8_rxData) { bool b_status = false; if(p_cdc_inst != (struct cdchf_acm *)NULL ) { int32_t i32_code = 1; if(! cdchf_acm_is_reading(p_cdc_inst)) { i32_code = cdchf_acm_read(p_cdc_inst, pu8_rxData, USB_PACKET_SIZE); } if(i32_code == 0) { b_status = true; } } return b_status; }
Thank you in advance
