User Interface?
85 posts / 0 new
Pages
Wow, you (joeymorin) are about 5 steps ahead of me. This is great stuff.
Is it me or was IrDa supposed to be the "next big thing" back in the 1990's? The plan was that electronic devices everywhere were going to be able to "talk to each other" by IrDa. Most PDAs, things like Palm Pilot (anyone remember?) and so on included IrDa so they would be part of this next great revolution. I think early blackberry's might have had it too? All this rather raises the question "where is it now?". I can't help thinking that things like range and light interference and just generally the fact that it took a lot of tweaking and was a pain to work with tolled the knell of parting ways for the technology. In this day and age it does seem that BT-LE and NFC are the kind of modern equivalent for letting two electronic devices have a "local chat" and they "just work".
I am exploring NFC also. Due diligence and all that.
One issue that I have is access to NFC in smart devices. It is not clear to me how to transfer plain data as opposed to some standardized financial transaction. I cannot tell if the NFC API in the smart devices allows that.
NFC may currently be "too new" and the very name (N=Near) suggests it might not be the best choice unless the device can virtually touch (in which case why not simply a cable?) . I would have thought Bluetooth (low Energy) was the established link of choice and I think there's only about a million things written on the internet showing how mobile apps can access the Bluetooth.
My goal is to be able to configure my instruments without opening the IP65 enclosure.
A bit leery of BT after way too many glitches, hiccoughs, with BT. Connections that don't get made between desktop and laptop computers, totally fubar with BT earphones, and a lot more. It, what ever "it" is, has to "just work".
My idea with the IR link is a cover that fits over the enclosure (plastic). The top of the enclosure is transparent polycarbonate. An IR transceiver on the instrument board and a complementary one in slip-over cover would be around 10cm apart and positively located with respect to each other. The slip-over cover could include a USB interface (such as FTD232R). A smartphone app that talks like a terminal through the USB port could then access the instruments configuration interface and set time, date, sample rate, and a variety of other conditions. Such a setup would be far more tightly constrained than Palm Pilot or Blackberry.
NFC should (technically) work equally as well, or easier, since many smart thingies have NFC built in (no extra interface device on a USB cable). Having the user simply place the smarty against the front of my instrument enclosure (they are actually close to the same size)  would insure proximity. This is a solution that is really attractive IF the NFC API in Android permits something more than just financial transactions. Trying to sort out this one, also. An alternative MIGHT be to implement my own non-standard NFC link, providing both ends of the link much like the IR idea.
Take a look at NFC beam:
https://developer.android.com/guide/topics/connectivity/nfc
There's a lot to digest here!
gchapman -
THANKS for that hint about megaAVR 0-series. I was planning on switching to a ATmega4808/9 so that is particularly sweet. The MCP2150 and siblings include 64 byte packet structure and that would be a bit of waste (especially for power) in my application where "packets" vary from a few bytes to a maximum of 25 bytes. I was also wondering if the CCL block could be combined with one of the UARTS to implement the RZI encoding and decoding but having an IrDA module built into the UART simplifies all that.
avrcandies -
Ahh, that is just the sort of thing I was looking for, re NFC.
Wow, strong hits on TWO obscure topics, IrDA and NFC, in one thread. Freaks are the best!
From what I have used BLE modules(ie. Rn4871 & BLE112) in my projects "it just works", I haven't had any connection proplems, once the module is in range I'm allready connected to it before taking phone out of pocket. API for ble in Android is well documented aswell, you implement couple callback methods and you are set, BLE stack will handle all the low level stuff for you.
There is NFC p2p mode in Android NFC implementation, but i think it's mainly implemented for android to Android communication in mind(Android beam).
Thanks, JoniS!
How relaxed is req. 4. ?
Snd does it split in som ways to stationary part and non fixed installation ? :)
The requirements list has shifted substantially.
It was originally written thinking that the "optimum solution" would be something like a display and keypad. The shift has been to something external (such as smart thingie) and a very low power link that does not require opening the enclosure.
Background: current device is configured via USB terminal. This requires opening the enclosure, which is problematic in a variety of only slightly extreme environments. The goal of this thread has been to find a way for the next generation product to be configured in the  field with a closed enclosure.
Summary: A variety of wireless technologies have been suggested and explored. Current technologies at the top of MY list are NFC and Infrared (such as IrDA). BlueTooth is a close third on my list. Others may rank things differently.
Item 4 in the original requirements (unit cost) has not been a big factor in the discussion. A solution involving a short-range link and external smart thing will cost a lot more than the specified amount but, in many applications, that will be "amortized" across multiple units (single interface device serving several instruments).
Is there currently an LED indicator of some sort on the existing design?  If so, consider an unusual approach:
http://www.merl.com/publications/docs/TR2003-35.pdf
Might require an extra I/O pin.  If you have one, and don't mind a green-wire mod, you could retrofit existing designs to provide a two-way link.  The other end could be a stand-alone device, or a bridge to a smart thingy.
Hm, I actually have 3 red/green LEDs (one for each accelerometer axis). Might be able to use one for transmit and the other to receive?
Gotta look at this!
Perhaps an alternative is a simple IR LED and IR photo transistor?
You don't have to transmit a signal across a room with varying amounts of sunlight, florescent light, tungsten light, halogen light, and various LED lights, all providing "noise" to your signal and decreasing your optical S/N ratio.
You have the ability to align the LED and the Photo transistor physically, and your separation is only several mm's, through clear or slightly tinted Plexiglas.
You also have the ability to mount the pair inside a lid that covers the data collection box, blocking out the ambient light.
The Photo transistor can feed the analog comparator module on the AVR, and simple UART Comms would likely work just fine.
Mount two pairs for bi-directional comm's.
Pack your data in a "data packet", with a checksum or a CRC, and use a simple got it, or re-send it, Protocol, with an error timeout, and a few "Command" packet options.
Weekend Project! wink
Cross post.
I suspect a true Photo transistor will be MUCH easier to configure for reliable communications that using a "normal" LED biased, filtered, amplified, etc., as a receiver.
I suspect you don't want a bunch of analog front end circuitry just to use a normal LED as a receiver, that would be a fun learning project, but not a great option for a commercial product.
If you end up switching to an Xmega for Ver II of the product, have a look at the different models and their analog comparator.
IIRC, some of them have software adjustable window detectors for the analog comparator, i.e. a fancy Schmidt input, where you can configure the hysteresis, and what action triggers the interrupt, (signal in window, higher than window, lower than window, etc., which makes for a "reverse logic" window, where the window is the dead zone, i.e. a classic, but adjustable, hysteresis input).
Edit:Typo
Don't need it.  The paper I linked shows clearly how it is achieved with only the LED, a resistor, and two I/O pins.
Agreed it is not the 'best' solution.  I mentioned it only because it may be a means of retrofitting Jim's existing products if that becomes desirable in the future.  For his new version (being built anyway as there are other enhancements apart from external config) a purpose-built solution is more sensible.
Likely spacing between an emitter and corresponding receiver is about 3cm of which a few mm is clear polycarbonate.
Some serious testing seems in order.
jim
We used a panel led as a detector to measure ambient light & control backlight---worked quite well (of course, easy compared to moving bidirectional data).   I had another project where I wanted a status "blink code" indicator; was told "NO" the customer won't allow any change or additions!!!...so instead,  to the user, the power on LED looks like it is just on, but is actually repetitively streaming just a few invisible bits.  I could use a scope & photodiode to check that certain internal modes are in effect & a driver current is within spec--no need to tear apart the sealed unit for diagnosis.  I wonder how many products do this without our knowledge?
For the fresh design effort, adding a photodiode is probably the easiest route, less hassle & costs a 10 cents.
Just reviewed the article that joeymorin linked. Turns out that it won't work in my present case because the LEDs I have are bi-color. The two different LEDs in each package are connected "anti-parallel" so there is never a configuration in which one of the diodes will work in reverse bias. So, that means that the current design stays as it is. Besides that, I doubt that there is enough code space to implement a software UART, or equivalent.
And, for the new instrument model, a proper IR sensor is really the way to go. You can get them with all the needed signal conditioning built in. So, there are lots of choices down that road (including NFC, etc).
Well it was a long-shot anyway...
On the idea  of  NFC, there is a Design News CEC online class-series scheduled for September that describes using smartphone NFC to control devices.
https://www.designnews.com/conti...
I was looking at NFC awhile back, the easiest solution was NFC chips that had some onboard EEPROM (could be flash) and I2C comms to a uC. Reading and writing to the NFC chip was done to the internal memory of the NFC chip, the uC would then read/write the contents of the NFC chip via I2C.
Not all phones come with NFC, NFC is still a feature limited mid-end and up phones.
For BT you have BT Low Energy modules, I do not know the idle power consumption but during active tx/rx the current consumption is about 25ma.
Ultra-Low-Power Micro Wields MRAM | Electronic Design
by William G. Wong
SEP 23, 2020
The Apollo4 microcontroller is TurboSPOT on, taking power down to much lower levels.
Summary :
  • Arm Cortex-M4 with secure boot and secure keys
  • 2MB MRAM
  • 1.8MB SRAM
  • VGA display interface
  • ADC - 12b, 2.8Msps
  • Analog microphone interface
  • PDM
  • I2S
  • Bluetooth 5.2
Apollo4 Blue - Ambiq
General availability will begin in Q1, 2021.
Too bad when you try to download a datasheet, all you get is 404 errors, no such file!
FF = PI > S.E.T
Where did you even see a link to a datasheet?
At https://ambiq.com/apollo4-blue/#documents all I see is
frown
Apollo3 (flash) are in-stock at some distributors with some PCBA and modules from some manufacturers.
Apollo4 (MRAM) - no datasheet may mean no engineering samples to customers as of now (a guess is Apollo4 is in initial characterization)
Apollo4 Blue Lower-Power System-on-Chip Family Product Brief via Documents | Apollo4 Blue - Ambiq
edit : Apollo4 samples are available; a guess is the datasheet is attached to a NDA until Apollo4 is released.
Ambiq Apollo4 Undercuts IoT Power – EEJournal
by Jim Turley
September 29, 2020
Unique Subthreshold Voltage Drops MCU into Microwatt Range
The display resolution stretches only to 640×480, so it’s not videogame quality, but it does support 32-bit color. Creating a convincing and customer-pleasing display is more about color depth than resolution, so Apollo4 should be more than good enough for smart refrigerators, home security systems, health monitors, and other GUI-rich devices.
Apollo4 is sampling now, so it’ll be a while before we see it in everyday devices.
Ambiq Micro Electronic Components Manufacturer — Octopart
Ambiq | Products - SparkFun Electronics
Apollo4 - Ambiq
Apollo4 with its 32-bit Arm® Cortex®-M4 core with Floating Point Unit (FPU) is implemented on the TSMC® 22nm ULL process. General availability will begin in Q3, 2021.
likewise for Apollo4 Blue - Ambiq
Apollo 4?
FF = PI > S.E.T
smiley
Similar test was done for precursor to Boeing Starliner (IIRC) (rocket ride, unmanned, hot reentry)
Ambiq Apollo4 is stocked.
Apollo4 | Ambiq eStore
Datasheet is apparently available behind an access wall.
Is Ambiq’s Apollo4 Plus the World’s Most Energy Efficient MCU? – EEJournal
by Max Maxfield
April 19, 2022
[seventh paragraph]
And then we have Ambiq, whose processors are based on their SPOT, with a core voltage of only 0.3V (this nugget of knowledge alone would have blown my socks off had I not donned special elasticated versions for the purposes of writing this column).
[two paragraphs before last paragraph]
A couple of weeks ago as I pen these words, Ambiq introduced the latest addition to the Apollo4 family — the Apollo4 Plus — which provides enhanced graphics display and greater voice capabilities to serve as either an application processor (AP) or a coprocessor for battery-powered endpoint devices. The Apollo4 Plus is now in mass production, targeting smartwatches and smart bands, consumer medical devices, motion and tracking units, and the smart home of the 21st century.
Pages
