Dipping into the well again....
11 posts / 0 new
So there has been success from Freakers in finding  RGMAW LED's and other items I am looking for on this little project of mine, so I will see if the well has run dry yet.....
I am in search of a Pan/tilt mechanism that is motorised.  Not Servo driven.  And can run off of a battery.  The load it must pan/tilt shall weigh no more than 16 ounces/~500 grams.
Ideally it will use stepper motors, but I am not too picky.  It would be great if it also had limit switches on it as well.
I ordered a unit off Aliexpress, and it arrived today, but is very disappointing to put it politely
JIm.
Are you looking for a $25 item, $70 item, $200 item (ex: difference between metal and plastic components)   Do you need a position feedback for each axis (beyond limit switches)?  is slow creepy adjustment ok, or does it need to move fast (like following a joystick in "real  time")?
This looked kinda neat---but maybe it is 100% garbage??? I don't know if it is servo, stepper, or nuclear
https://www.ebay.com/itm/1750495...
I saw a similar mount and it certainly fits the specs, but I forgot to mention that the mount needs to sit flat on a table, or on the ground.
Thanks for teh lead though.
JIm
You could mod with a bandsaw, at least it would sit flat....maybe these folks make 10 variations...finding ou t who is the fun part
Yup.
This is a bit of a niche project.  Not too sure how its all going to pan out (no pun intended).  I also may need 10 of these so a bandsaw mod wont look so neat.
The search continues
JIm
Have you looked at the T/P mounts used on drones?
Would that work for you? something like this:  https://www.adafruit.com/product...
FF = PI > S.E.T
YEs, and they are not strong enough to tilt a 16oz/500G object attached to them.  They also use power to stay in position so battery pack life suffers.  Hence usiing a motorised mount.
Right side Jim
Thanks for the clarification of the spec's Jim!
FF = PI > S.E.T
So you don't want RC servo drive (Technically, PWM-driven potentiometer feedback gear motors), but you're okay with steppers.
The weight of your load is mostly irrelevant, what's important is the torque you think it should maintain without power applied.  That will definitely imply a gear motor - steppers will backdrive given a bit of torque on them, so you will need to put power into them to keep them still (rather more than RC servo drive, I'd think!).  I could be wrong - feel free to correct.
The best anti-backdrives are going to be worm gears.  This outfit has some:
http://www.eaglepantilt.com/
Never mind.  They updated their website, and are apparently out of that business.
S.
PS - If it helps, I know an outfit that does make highly geared pan-tilt assemblies, but they're not really generally into selling them separately.  They have about 100:1 geartrains, and are servos, but not in the 'RC' servo sense - they have optical encoders on them and are dependent upon proper driving and feedback control electronics.  You could probably use a couple of $250 'geckodrives' to run them, but the mechanical assembly would probably run well into four figures.  At a certain point, it becomes cheaper to make your own.  S.
Maybe just screw the arm down on a chunk of extrusion or steel plate.
Most of these lightweights will need some sort of base to stay put, or they'll blow over when you sneeze and change direction if jostled.
NOt sure if this is a question, or a confrontation, but I am going to go with the former...Yes, Steppers is the way I would like to go, but I am open to other ideas.
If you short the coils of a stepper motor the motor will not turn...easily.  The ones I have here wont even turn when I anchor their mounting flanges in a vise and try turning the shaft with a pair of pliers.  So in theory I could energise a low power relay when I want to connect the stepper driver to the coils and spin the motor, then de-energise the circuit/relays and the motor will hold its position.
Yes, and the smoothest movement too.
Thank you for the offer/idea.  We are thinking of using the crappy P/T mount we bought from AliExpress and have my metal shop make a 'beefier' unit from my shop drawings.  I have to dissect the crappy one first though.
