Has anyone seen issues with the SAMG55 (or similar) where the various clock frequencies are incorrect? My clocks are derived from a 32.768kHz input, which I have verified is accurate. I noticed the issue because my console port that was set to run at 115200 baud produced gibberish unless I dropped the speed to ~103k in my terminal program. I scoped the lines to confirm the issue was coming from my board and not the terminal program or USB->serial converter. I also scoped I2C lines derived from the same clock, and they are running at ~90.9kHz instead of 100kHz as set. So the internal PLL output of the chip seems to be roughly 10% too slow. This is a custom board, and the other units do not have this issue. All are running the same firmware.
I suspect ESD or similar may have damaged the chip and with it the PLL, and I'm about out of ideas other than swapping out the processor for a new one.
Any suggestions before I resort to that?
