Parts are getting hard to find......
12 posts / 0 new
I am looking for a small...low parts count switching regulator(s)
Spec is as follows:
Input voltage is 15-40 volts DC
Output voltage is 12volts, or 5 volts
Output current is no higher than 200mA for each voltage, but I would like a regulator that can do 500mA if possible.
Prefer to use as small an inductor and capacitor for inputs and outputs as possible.
SMD package
I have to generate a 12vdc rail, and a 5vdc rail.  So if I use an adjustable regulator, I use two and change the feedback resistor(s).
Problem is...  Theres no stock at most of teh usual suspects.
Linear regulators I can get.  Might have to use those until things become available again...in a few years
“Everyone knows that debugging is twice as hard as writing a program in the first place. So if you're as clever as you can be when you write it, how will you ever debug it?” - Brian W. Kernighan
“Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.” - Antoine de Saint-Exupery
I was going to suggest L5970D I have used lots of them in the past but I don't have any left and neither does Digikey. sad
Thats a nice part.  Certainly meets requirements.  $4.00 a piece.  OUCH!  But times are tough
Good suggestion, and I thought of it as well, but I need teh input voltage near +40vdc for surge reasons as this might go into a hostile power environment
THAT might be a winner!
I think I can get away with not using SOIC and instead the DFN package for final work.  Too bad no SOIC or DIP where I can make up a quick prototype of teh power supply for testing
Thanks all!  Keep the ideas coming.
JIm
Monolithic Power Systems modules are on Arduino Nano Every.
re that module, good price though am personally leery due to the current supply chain issue (container ships may still have a long queue at US ports)
NANOEveryV3.0.sch (grid A1)
MPM3610 | 21V Input, 1A Module Synchronous Step-down Converter with Integrated Inductor | MPS
Pololu 5V, 300mA Step-Down Voltage Regulator D24V3F5
edit :
MPM3570E | Ultra Low EMI, 75V Input, 0.3A Step-DownPowerModule with Integrated Inductor | MPS
edit2 : MPM3570E may have a very long lead time
Of course the next drama may be the inductors regardless of device used.
Thanks to this thread I found a few more Xmegae5 chips laugh you keep on helping out even without trying Jim.
the original simple switcher is widely copied LM25xxx LM26xxx and goes to 40V or 42V
or maybe
oldie--but low cost:
These MC34063 are not so much that--they run around 100kHz, the 1-2 MHz parts will have smaller inductors
Take a good look here: https://www.mouser.com/datasheet...
BD9G102G-LB  In stock (Mouser & Newark), and decent price ($1.11 @ 100)
They have fixed voltage styles, if you wanna save a few resistors (but then your IC quantity price gets cut in half)
Since the Driver is mostly off (duty 5/40, or 12/40) , a synchronous FET type would have better efficiency than the schottky diode loss at the higher input voltages....but much rarer birds. and more $$
LM2596, nothing else (for 40V input).
Edit: If you can be happy with 35V, then the price is 2$, board is like this.
There are zillions of offers in EB/Ali.
Tell me about it Jim, I've been forced to go to Ebay or Amazon for the parts I need to do equipment repairs, Amazon is quicker on delivery but limited on what parts are available, Ebay is slower but so far I have been able to find what I need.
Flyover Jim
FF = PI > S.E.T
Did not see any at mouser, but on a secondary market they had them.  Went with those.....Candyman gets teh win.
Yeah, no S***! I had to go hunting for teh ones I needed.
