Humidity Transducer?
29 posts / 0 new
Total votes: 2
Feeling bummed 'cause I have not made anything for a long time. I seem to have lost interest in trains and can't think of anything to make not train related.
How about a weather station?
I have some hall effect sensors -- this will do for counting anemometer speed.
Lots of IR leds and sensors -- I'll make a gray code encoder ring to connect to the weathervane to give me 8 compass points.
LM35 temperature sensor -- For temperature.
Just ordered some MEMS barometers. Oh, they have temperature sensors built in. Might not use the LM35's
I'll power the outside unit with D batteries. Use NRF24L01s to transmit data to display inside. Use TFT for inside display.
But how to sense humidity?
(Yea, it's an autistic thing to suddenly use a 20-year "special interest.")
Sensirion, (SHT71), has great Temp and %RH sensors.
Bosch, (e.g. BME280), also has really cool Temp, %RH, and Barometric Pressure sensors.
The sensor itself is incredibly small, so buy a breakout board for the sensor.
Below is a repurposed PCB when I was working with the BME sensor:
The PCB below shows the little pink/purple BME breakout PCB at the top edge of the main PCB:
What happened to the photographic interest? surprise
Pleased to see you back here Tom. Belated Happy New Year to you.
Ross McKenzie, Melbourne Australia
Welcome back, hope all is OK.
As already suggested, go for the BME280. It is easily interfaced, IIRC was very current efficient and small, so would easily fit anywhere. Ada-Fruit or sparkfun should have breakout boards sowill make 'playing'  a lot easier.
I know the interest part... have been working on a datalogger, decided to make a PCB using an ARM processor to have a play with that and after I got to a certain point interest just disappeared. It recently has somewhat come back as I found a use for the thing so now seem to be wanting to make it work again.
BME280 for sure, here it is, pink square on the right.
Go old school and make something based around the Wet Bulb technique. Much more challenging than just buying a purpose-built sensor.
plenty to choose from; eg,
https://www.sparkfun.com/product...
A complete WX station, I know, it takes all the fun out of it, but it's open source, so look it over and take what you need.....
Glad to see you back!
FF = PI > S.E.T
Still do that! It's a little too cold for barefoot droning right now
Hoppy Gnu Ear to you!
A little cold for barefoot brats!
Wet pad around one bulb and swing it around on a string!
Why didn't I think of SparkFun and Adafruit?
Check your PM's Tom.
What about photography and droning? Well....
All the electronic parts are here. I got the HTU31-D QT from Adafruit. Strangely, they refused to ship to my UPS box where everything is kept in a secure place, preferring my mail box.
Some mechanics are done. Here I 3d printed the rings of my Stevenson screen. Maybe I should move this to "Projects?"
Tom, you should paint your screen a highly reflective white colour for most accurate performance.
It IS a highly reflective white. Just a silly photographer who did not change the white balance for my "Warm white" LED lighting. But I might paint it exterior white anyhow.
Torby wrote:
... from Adafruit. Strangely, they refused to ship to my UPS box where everything is kept in a secure place, preferring my mail box.
UPSindecision  USPS?  If yes then had the same issue with Battery Tender®; local postmaster gave me the physical address of that post office.
<USPS office address>
#<USPS box>
city or town, state, USPS zip code
That postmaster is keen on scanning parcels and such; tracking updates very quickly.
USPS.com® - USPS Tracking®
Part of the most recent conversation with that postmaster was parcel security; here, parcels left on your front porch can be blown off the porch by the wind.
I think you can get a mail box at some UPS stores.  I thought they bought out Mail Boxes Etc., but it seems they are still around too.
#<USPS box>
I have a box at the local UPS store. Adafruit considers such things fraudulent, so I had to have them ship to my house.
I have a handy next door neighbour laugh. So far this week he's had a box of electronics from China and a paraglider returned from its bi-annual legal test.
There's a DHL/Bundespost locker block at the supermarket down the road, but for some reason it's never offered as a destination when we get to the 'your parcel is arriving soon, where would you like it?' stage.
Neil
barnacle wrote:
and a paraglider
Wow that is gonna be a LOT of brown paper, string and sealing wax !!
clawson wrote:
barnacle wrote:
and a paraglider
It's all right. I'm allowed to send it in for testing folded up. A box about 50x50x30cm, total weight about six kilos.
Neil
I have some little bearings left over from a previous 3d printing project that I figured I'd use on the weather vane and the anemometer. They fit m3 screws, so I decided to order some 3mm shaft. All I got was an empty envelope with a rip where they had escaped. Second try got me some nice 3mm shafts, 300mm long. Hmm. These don't fit through my bearings. Rats, battery dead in my good caliper. Cheap caliper says 3.0 mm.
Unless way off, might make a nice press fit (don't damage or distort the races).  Heat the bearing in a toaster oven.  Then you'll need a good shaft puller later.
That sounds reasonable, but I'll have to wait till later in the project to try it.
Outdoor need special plastics in printing 3D.
www.tokopedia.com/madagang .Buy and Donated cheap electronics and manuscripts.
