Some C instruction disappears when I complie the project, ATtiny416
4 posts / 0 new
Hi everyone,
I'm using the ATtiny416 with the Microhip Studio 7, and I have encountered a problem.
When I compile some instruction disappear on the disassembled file, and in fact ther are not executed
In particular when copying a value from an array to a global/local variable, and all istruction that use that varible disappear.
Example
unit8_t array[] = { 1 , 6, 10, 4};
uint8_t ciccio = array[0];
There is nothing in the disassembled file...
How can I solve this problem?
PS: Usually I code with assembly, but this is a simple project so I decided to use C.
Those that are not used by the optimization will be deleted.
If you don't want to be deleted, suppress it.
volatile unit8_t array[] = { 1 , 6, 10, 4};
volatile uint8_t ciccio = array[0];
As Kabasan says, this will be due to compiler optimisation.
See: https://www.avrfreaks.net/forum/tutcoptimization-and-importance-volatile-gcc
Although that tutorial focuses on avr-gcc (as used by Microchip Studio), Note that optimisation is a general feature of (pretty much) any compiler for any target.
Thanks, now I understand everything!!
I knew that the problem it was related to me because I don't know the complier very well.
Have a nice day and thank you to the immediate reply laughheart
