working srf05 with 3.3V
14 posts / 0 new
Hey there
is it possible to work with SRF05 module in 3.3V?
Do you have 5v rail in your system somewhere or just 3.3v only?
“Everyone knows that debugging is twice as hard as writing a program in the first place. So if you're as clever as you can be when you write it, how will you ever debug it?” - Brian W. Kernighan
“Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away.” - Antoine de Saint-Exupery
all of system work with 3.3V
my MCU is stm32
It is the /almost/ same circuit as SR04, so: 5V only.
How I can connect 5V module to 3.3V MCU?
This says 3.3V or 5V:
https://www.adafruit.com/product/4007
You need a level shifter between them. It can be simplified if you know schematics, for example if 5V does work "open collector".
As for 5V, it is easy to provide by one of cheap board, search for this:
0.9-5V To 5V DC-DC Step-Up Power Module Voltage Boost Converter Board 1.5V 1.8V 2.5V 3V 3.3V 3.7V 4.2V To 5V
does this "3.3V MCU" have 5V-tolerant IO pins ?
EDIT
Oh - I missed:
hasanzadeh99 wrote:
my MCU is stm32
So, as Ross said (below), why are you not asking on ST's own forum?
See your other thread: https://www.avrfreaks.net/commen...
Some pins on STM32s are 5V tolerant - see the datasheet for details.
hasanzadeh99 wrote:
my MCU is stm32
So why aren't you  asking your question over at their site?
Ross McKenzie, Melbourne Australia
What MCU module that you had ?
www.tokopedia.com/madagang .Buy and Donated cheap electronics and manuscripts.
Seems he now has: https://community.st.com/s/question/0D53W00001NWTmISAX/is-it-possible-to-connect-srf05-module-ultrasonic-to-stm32f030k6t6-and-work-with-33v
clawson wrote:
This says 3.3V or 5V: https://www.adafruit.com/product...
But that seems to be  a slightly different module:
Which, of course, raises the question: if 3.3V operation is important, why not just pick a 3.3V module in the first place??
yeah I know that. What I was suggesting is "why have a battle with 3/5 boundaries if you can buy almost exactly the same thing in a 3V ready form to start with?" Too often we seen threads here about people designing system with the "wrong" components and then having an uphill struggle to make it work. But if you design in the right components from the start you can have a smooth, carefree journey to the solution instead.
(of course if you already ordered 10K pieces of the 5V one and "have to make it work" then I guess that's different but, as always, doing the upfront design work pays dividends and that includes designing in the right components in the first place).
yes STM32 module had 5V and 3,3V
