Hey there
is it possible to work with SRF05 module in 3.3V?
Hey there
Do you have 5v rail in your system somewhere or just 3.3v only?
all of system work with 3.3V
my MCU is stm32
It is the /almost/ same circuit as SR04, so: 5V only.
How I can connect 5V module to 3.3V MCU?
You need a level shifter between them. It can be simplified if you know schematics, for example if 5V does work "open collector".
As for 5V, it is easy to provide by one of cheap board, search for this:
0.9-5V To 5V DC-DC Step-Up Power Module Voltage Boost Converter Board 1.5V 1.8V 2.5V 3V 3.3V 3.7V 4.2V To 5V
does this "3.3V MCU" have 5V-tolerant IO pins ?
EDIT
Oh - I missed:
my MCU is stm32
So, as Ross said (below), why are you not asking on ST's own forum?
See your other thread: https://www.avrfreaks.net/commen...
Some pins on STM32s are 5V tolerant - see the datasheet for details.
my MCU is stm32
What MCU module that you had ?
why aren't you asking your question over at their site?
Seems he now has: https://community.st.com/s/question/0D53W00001NWTmISAX/is-it-possible-to-connect-srf05-module-ultrasonic-to-stm32f030k6t6-and-work-with-33v
This says 3.3V or 5V: https://www.adafruit.com/product...
But that seems to be a slightly different module:
Which, of course, raises the question: if 3.3V operation is important, why not just pick a 3.3V module in the first place??
(of course if you already ordered 10K pieces of the 5V one and "have to make it work" then I guess that's different but, as always, doing the upfront design work pays dividends and that includes designing in the right components in the first place).
if you design in the right components from the start you can have a smooth, carefree journey to the solution instead.
