sending a variable to lcd
11 posts / 0 new
hi,
i'm working with a lcd at the moment, so i can use it in other projects. i have figered out most of the functions, but for some reason i can't send variables to the lcd. only stuff like:
lcd_putsf("test");
delay_ms(200);
does anyone here know how to send a variable?? i searched on google, lots of forums (also here) but i can't find it.
i'm using a HD47780 competible lcd, code is in CodeVisionAVR and the Atmega16L is the processor.
thanks robbin[/code]
Something like:
char lcd_buffer[40];
sprintf(&lcd_buffer,"My variable is %i",variable);
lcd_putsf(lcd_buffer);
what do i need to include to use sprinft, i get an error when using that function
//i found that one.
sprintf(&lcd_buffer,"My variable is %i",x);
i get 2 errors:
in the first code sentence i get: illega address,
second sentence: function parameter incompatible with it's declaration.
thanks for answering
Posting your code would help. And always post the name of the errors you get. Try including stdio.h and stdlib.h . Sprintf is IIRC located there...
Oh, and RTFM: http://instruct1.cit.cornell.edu...
i was editing the my post :), i figured out that i need stdio.h.
i now have the errors mentioned above yours. do you know how i can fix that?
thanks
Ah! Got it! Instead of
use
lcd_puts(lcd_buffer);
putsf loads a constant string from the flash, say
lcd_putsf("This text will never change");
while lcd_puts can insert variable text.
daqq wrote:
Something like:
Sorry daqq. With CodeVision you have to distinguish between flash strings and SRAM strings.
So you use:
lcd_puts(lcd_buffer);   // because lcd_buffer is RAM
lcd_putsf("String in flash"); // because in FLASH
But the principle is the same. Use sprintf() to convert your variable into a string, and send this string to your LCD.
ah, that helped alot :), for some reason i get also the error Illegal address when i use the sprintf:
x = 55;
sprintf(&lcd_buffer,"My variable is %d",x);
i thought that it maybe was de %i, so i changed it into, %d, %f, %s, but none worked.
many thanks for your help
Robbin
oke i have it, i think it was a typo
that doesn't belong there :P.
thanks for help
bye
Oops. I had not noticed the &lcd_buffer.
You should either do &lcd_buffer[0] or lcd_buffer.
Your code was correct, Daqq had the type, but that doesn't matter, the problem is solved.
i combined the lcd with the ADC, i get some value's, but not the right once.
for 5v i get 255 (logic, cause it's 8bit)
for 0v i get 204...(not logic at all).
and when it's not connect i get value's from 0 to 6??.
here is the code:
#include
#include
#include
// Alphanumeric LCD Module functions
#asm
   .equ __lcd_port=0x18 ;PORTB
#endasm
#include
#define ADC_VREF_TYPE 0x20
 char lcd_buffer[16];
 int x;
// Read the 8 most significant bits
// of the AD conversion result
unsigned char read_adc(unsigned char adc_input)
ADMUX=adc_input|ADC_VREF_TYPE;
// Start the AD conversion
ADCSRA|=0x40;
// Wait for the AD conversion to complete
while ((ADCSRA & 0x10)==0);
ADCSRA|=0x10;
return ADCH;
// Declare your global variables here
void main(void)
  DDRB = 0xFF;                                      // We put port D pins in output mode
  PORTB = 0xFF;                                     // we activate the internal pull-up
  DDRD = 0xFF;                                      // We put port D pins in output mode
  PORTD = 0xFF;                                     // we activate the internal pull-up
// ADC initialization
// ADC Clock frequency: 115,000 kHz
// ADC Voltage Reference: AREF pin
// ADC Auto Trigger Source: Free Running
// Only the 8 most significant bits of
// the AD conversion result are used
ADMUX=ADC_VREF_TYPE;
ADCSRA=0xA5;
SFIOR&=0x1F;
// LCD module initialization
  delay_ms(30);	                                    // delay for lcd
  lcd_init(16);                                     // init for lcd
  lcd_clear();                                      // clean up screen
while (1)
      x = read_adc(0x00);                           // x = ADCH
      sprintf(lcd_buffer,"Result: %i",x);           // convert the value to string
      lcd_puts(lcd_buffer);                         // make visible on lcd
      delay_ms(200);                                // delay to see chances
      lcd_gotoxy(0,0);                              // go to the first row/colum
      if(PIND.1 ==0)                                // clean op lcd
          lcd_clear();
          delay_ms(200);
hopefully we can get this working, would be nice :)
