Debug and use SPI on ATtiny at same time
10 posts / 0 new
Hi folks,
I'm currently developing on ATtiny84A and begin to find very difficult to continue without a proper debugger.
So I've bought the AVR JTAG ICE and make my research and find that if I want to enable debugging (debugWire mode) on that chip,
I would have to enable the fuse DWEN which one disable the SPI port (that I need for a peripheral).
My question is : Is there any solutions to debug my chip keeping the SPI port UP ?
Thank's in advance.
Mike
IOT is the future of the présent ;)
No,   when AS7.0 enables debugWIRE for you,  it sets the DWEN fuse.   This makes the dW pin functional for programming AND debugging.
The USI pins are free from programming duty i.e. use them for SPI, I2C,  UART or whatever.
You just leave the Tiny84 in debugWIRE mode for the development cycle.
Just remember to restore ISP when you go on holiday or have finished the project.
It is always wise to use real-life pullup resistors on the /CS pins of all SPI devices.
Does it?
Doesn't it just disable ISP - not the entire SPI function?
Tiny84 has no proper SPI, I2C or UART peripherals.   Just USI which works pretty well for implementing Slaves.
You can of course use USI as an SPI Master.   It is just a bit crap compared to a proper peripheral.
The USI pins are shared with ISP.   So any external SPI slaves must play cricket during ISP (or debugWIRE disabling).
Hence external pullups on /CS pins.
This is exactly the same as ISP programming on a Mega32 or 328P.   External SPI slaves must be inactive during ISP.   Hence the expense of buying resistors.
Welcome!
So I've bought the AVR JTAG ICE ...
fyi
debugWIRE via USB UART | AVR Freaks
I don't think that supports debugWIRE ?
EDIT
It's not listed on the Product Page, but the Quick Start Guide says it does
https://www.microchip.com/en-us/development-tool/ATJTAGICE2
https://ww1.microchip.com/downloads/en/DeviceDoc/doc2562.pdf
Mk II, that is.
Maybe get familiar with this diagram (which I very nearly made into a t-shirt for Morten) before you dabble with DWEN yourself (this job is best left to Studio):
https://onlinedocs.microchip.com...
+1
And be sure to follow the prompts - you do need to power-cycle when it tells you to power-cycle.
IIRC:
JTAGICE supported only JTAG & ISP
JTAGICE mkII added debugWIRE
JTAGICE mkII rev B added xmega PDI
JTAGICE3 added SWD and made it all faster (and 'corrected' the PDI pinout)
A picture paints 1,000 words and there is probably 1,000 words in here too.
