Atprogram with atmel ICE
21 posts / 0 new
Hello sorry if this is in the wrong place but i have exhausted myself trying to figure this out.
I have an Atmel ICE programming an ATmega88PA. I am normally running STK500.exe with an AVRISP mkII but have been unable to use this method with windows 10. I am trying with an Atmel ICE and atprogram but i am unable to get this programmed correctly.
"atprogram.exe" -t atmelice -i ISP -d ATmega88PA program -f "File.hex" -ee -f "File.eep"
I am sure i have made a mistake somewhere in this but i have been unable to find anything that could help.
Any help would be greatly appreciated.
What does not work?
Make sure you do a --chiperase before program if there's already stuff on the device...
:: Morten
My chip erase is successful
 "atprogram.exe" -t atmelice -i ISP -d ATmega88PA chiperase
But when trying to program using the .hex and .eep file I just get[ERROR] An error occurred executing a command (program): Unknown file format. Specify a valid format with the --format option.
Have a look at the first few lines in File.hex and File.eep then. Are they actually Intel Hex or something else?
You'd hope to see something looking like...
D:\junkavr\testGCC\testGCC\Debug>head testGCC.eep
:00000001FF
D:\junkavr\testGCC\testGCC\Debug>head testGCC.hex
:100000004FC0000055C0000053C0000051C00000A8
:100010004FC000004DC000004BC0000049C00000B0
:1000200047C0000045C0000043C0000041C00000C0
:100030003FC000003DC000003BC0000039C00000D0
:1000400037C0000035C0000033C0000031C00000E0
:100050002FC000002DC000002BC0000029C00000F0
:1000600027C0000025C0000023C0000021C0000000
:100070001FC000001DC000001BC0000019C0000010
:1000800017C0000015C0000013C0000011C0000020
:100090000FC000000DC000000BC0000009C0000030
Yep both files look like that.
The .eep and .hex files have been used for years on STK500.exe with AVRISP mkII with no problems at all but are not working with atprogram and Atmel ICE
atprogram does not recognize .eep as a valid file format, you need to tell it it's a hex file with --format hex -f file.eep
or rename it to file_eep.hex
FF = PI > S.E.T
AVR Studio 4 can run on Windows 10 though Jungo is a concern.
Sep'20 :
Earlier are Feb'18 and Nov'15.
Good Lord - of all the people in the world who might know what format to expect in a .EEP file you might have thought Atmel would know ?!?
Well, we do now wink(as of 7 minutes ago)
:: Morten
I guess atprogram is considered just a dumb command-line utility, and they put the "intelligence" to add the --format hex in Studio ?
Studio does not use atprogram
:: Morten
Dare I ask "why ever not?". As it stands you're presumably maintaining two parallel developments of software doing virtually the same thing.
Nope, they are both frontends to atbackend, where most of the meat is...
Why would a whole IDE frontend talk to a programming only CLI?
Actually just had to check, atprogram is ... 5700 lines of python code (i.e not very dense), mostly dealing with managing the resources in the atbackend process (a TCF concept for those that wants to go down that rabbit hole). A atprogram command ranges from 39 lines (reset) to 553 (info).
:: Morten
Thanks Morten!
FF = PI > S.E.T
I have finally been able to get it working
"atprogram.exe" -t atmelice -i ISP -d ATmega88PA chiperase program -f "HEX.hex" program -ee --format hex -f "EEP.eep" write -fs --values 48DEFF write -lb --values C0
The problem i now have is that it is running to slow. 3x slower than when using STK500.exe and AVRISP mkII. Any idea how this could be made faster
pymcuprog?
https://github.com/microchip-pic-avr-tools/pymcuprog#readme
edit : oops (no mega88PA)
https://github.com/microchip-pic-avr-tools/pymcuprog/tree/main/pymcuprog/deviceinfo/devices
Increase the clock rate of ISP? Merge the chiperase and program command (instead of chiperase program, do program --chiperase).
  -cl --clock <arg>          The frequency to use for communication with a
                             device (hz, khz, mhz, default hz). E.g. -cl 10mhz
:: Morten
Concur
Pololu - 5.7. Programming faster
Program the fuses first to set a higher clock rate, ie. clkdiv8 disable, then set ISP speed higher for the rest of the programming....
FF = PI > S.E.T
Good point!
Also IIRC the clock setting might be sticky on the Atmel-ICE, so always best to specify it explicitly anyway.
Some of the time is spent bringing atbackend up and down. If you are doing a lot of programming you can start the backend manually to have it running continuously, and then connect to it with atprogram using the --host and --port options.
