No Such File or directory
19 posts / 0 new
In my code I've included DS3231.h, as seen below, but when I compile, I get a No Such File or Directory.
  • The path is included in my tool chain directory
  • It's showing under libraries in solution explorer
	///////////Preprocessor Directives////////////////
	#include <Arduino.h>									//Arduino functions
	#include <SD.h>										//SD card library
	#include <SPI.h>									//Serial peripheral interface (SPI) library
	#include <avr/io.h>									//AVR device specific IO definitions
	#include <inttypes.h>									//This header file includes the exact-width integer definitions from <tt><stdint.h></tt>, and extends them with additional
	#include <util/delay.h>									//Convenience functions for busy-wait delay loops
	#include <DS3231.h>
I took some screen shots, but its not letting me paste them in, so they are attached for your consideration. Any help or guidance you can provide would be greatly appreciated.
-Tim
Tim Watson
When you include a custom library, you must put double quotes around the name rather than <>.  (Not that I've ever made that mistake or anything)
#include "DS3231.h"
Also, there's an "add attachments" button under the text editor if you want to add a screenshot.
Jarrod
Edit:  Sorry, I just saw your note about the path being included in the toolchain, so my solution may not be correct.
Yes, I did try #include "DS3231.h", but I get the same message.
Tim Watson
I tried to include some screen shots, but it doesn't seem like thats possible here
It seems to have been broken again however copy and paste still works (photo of a part I'm looking for my Sunbeam toaster sad)
I usually put all my file in one project directory for the simple reason that I may have to hand everything over to a client.
I gave it another go, but still no luck pasting the screen shots in, so I've shared them as an attachment.
-Tim
Tim Watson
Just copied and pasted both above. wink
Thank you! Any idea what I'm missing that's causing the compiler to hang?
Tim Watson
Sorry, unfortunately not sad It seems to find the other 2 library files SPI and SD?? Unless the DS3231.h is before the other 2 and the system crashes before looking for those other 2 files.
directory "Hawking R3p2" has a space in it. As I recall, Studio has problems with directories or files with such names. Something about enclosing the full path in quotes or such?
Thank you for the suggestion ka7ehk..I replaced the spaces with underscores, but the issue persists.
Tim Watson
It's more helpful if you give the "Output" data as a paste of the actual text rather than a PNG graphic. The interesting bits are those that are NOT seeing rather than those that we are!
On the line below "Invoking" where it actually runs avr-g++ I would like to see the -I's
Also you have specified them as relative paths but are they right (the right number of ".." at the start)? They will be searched relative to the location of Sketch.cpp. So is your ./include/ actually at ".." beneath Sketch.cpp ?
Another useful thing to do is switch to a command prompt and CD to the project directory and then give the "tree /f" command and paste the text output of that here - it will reveal the actual layout of .cpp and .h on your disk in that area. (you may need to "go up one", that is "cd .." and do it again if the output does not contain the tree under "include")
Ultimately ZIp the entire project directory and attach here and I'll tell you exactly what is wrong.
That's not necessarily true.
https://gcc.gnu.org/onlinedocs/cpp/Search-Path.html
The thing is that both
#include "DS3231.h"
and
#include <DS3231.h>
give only the name of the file - they say nothing about the location of that file.
You have to set up your Include Paths to tell the compiler where to find #included files:
See: https://www.avrfreaks.net/commen... for illustrated instructions
in summary:
EDIT
Note that the above is for a C project; in a C++ project, you get two separate entries - one for the C compiler, and one for C++:
(sorry, the image posting is broken again - see attachment)
EDIT 2
2nd attachment - annotated to highlight C and C++ options
Well they do a bit. whether "" or <> is used influences where the preprocessor will look for the .h. For "", by default, it will only look in the same directory as the source file that does the #include whereas for <> it looks there but also, then, in the configured "system path" locations (which is the part of the compiler/library installation where things like stdlib.h, math.h and so on are located).
Oh boy how I would love to be able to paste pictures! But you must be seeing something different in #1 to what I am seeing?? He has a list of 7 directories.
Oh wait a minute, got it....
... the issue is that both "C" and "C++" have their own separate sections for "Directories". In #1 the list (including the "DS3231") are listed for the C compiler so it's set under the WRONG set of "Directories". Sketch.cpp is a C++ file not a C file.
EDIT: SNAP - you edited that at the same time!! ;-)
Yes, I realised that in my edit - but, by then, the image paste had broken again.
frown
Oh well at least it isn't just Brian and I stuck out in the picture-less wilderness then!
Indeed. frown
It's intermittent - I managed to paste the 1st image into #12, but then couldn't paste the 2nd for the EDIT.
(and now it's still not working)
They don't need to all be in a single directory for that - just so long as they're all under a common project "root" ...
awneil wrote:
Indeed. frown
Andy I have copy/pasted the two images... hopefully as you intended.
Ross
Ross McKenzie, Melbourne Australia
Thanks.
yes
